White top huaqvarna 44
old guy
Love me some Husqvarna
11:27 AM
Becker Minnesota
I was just given this saw, little bugger runs great, however it does not oil.
It has no oil pump so I assume it must pressure the oil tank somehow.
It also smokes a little so I'm guessing bar oil is getting into crankcase.
Can somebody educate me?
Woodwackr
10:27 AM
ID
It has a pump.
12:27 PM
It has to have a pump. Generally have to pull clutch to get to it. Not familiar with the model.
Remember that the clutch has REVERSE threads so that it stays tight while the saw runs. You rotate it CLOCKWISE to loosen it. Use rope through the pug hole as your piston stop, you won’t brake much that way.
Agrarian
12:27 PM
New Hampshire
Yes, as the good doctor says. It looks like this. They're identical except for the color and the pre-bend of the oil hose.
old guy
11:27 AM
Becker Minnesota
Thanks Woodwacker, yeah, I just did more research and saw that, those parts are gone from my saw and it looks like no longer available.
Thanks fer the pics, but the pump parts are missing from the plate on this saw.
Agrarian
12:27 PM
New Hampshire
Maybe not available from the dealer but certainly from eBay.
David Boyd
12:27 PM
Cape Charles, VA
can also look for a donor saw.
Often with the older saw, it is easier and more cost-effective to buy somebody else's scrap, saw and steal parts off that
old guy
11:27 AM
Becker Minnesota
Well, I'm gettin more education on this oiler, the plastic gear that drves the oiler was so bad I did not recognisize it as a drive untill I drve it out, then I could see the oiler.
Also someone had tried to drill out the plastic plug that holds the oiler in so that was an unrecognizable mess.
The oiler is now jammed in with black plastic pieces of the drive.
Then I spotted the setscrew that holds plastic plug in and things started to move. I gotta learn to check a diagram when I find something different.
Found parts on Ebay but only one had the plastic drive gear.
Woodwackr
10:27 AM
ID
I may have a spare…will check.
But. Try Berry’s on eBay. That’s where I got one a while back.
