460 magnum
- 9:18 PM
- Apr 26, 2016
- Very southern Illinois
I've never had one break like this before
+1 I broke a tensioner on a 394 when the bar nuts loosened and I didn’t catch it in time.Bar/clutch cover nuts not tight enough?
Too much force been resting on the chain tensioner.
That would be my best guess.
No on the bar nuts being loose. I know this because I can think back and remember having to loosen them with some pretty good force. Only thing I can account for is making the bore cut the saw made a couple bucks and pop... Maybe even a faulty part from the get go.
I used to do that with 660s. Only took 2 times to figure out what was doing it. You had the rakers to low and a violent chain 1 to many times using the tip to bore. Combined with not having the nuts tight enough. Don't be afraid to crank them tight. Its a saw not a trinket.Ok got the new chain tensioner in and here's a pic of the one that beikeView attachment 146031 View attachment 146032
I would say the bar nuts were not tight enough for the force that you had put on it, may have felt tight but must have slid and broke the tensioner, on long bars I tighten the tensioner then the bar nuts then back off the tensioner so there isn’t any load on the tensioner...
Where’s the sensitive members thread?
Having read the "stroker 661" thread, more than once I had to ask my mechanic why I wood want another heavy, noisy, large ☆ss saw? Told me I was a motor head and wanted to mill faster? Now that I unnerstan where is the line?all the mods add up. just depends on how far down the rabbit hole you wanna go.
Happens to me every other time I adjust the chain without loosening the bar nuts. Carry extra parts in a tackle box, complete drop in adjuster assembly. Blew up a drive sprocket once on a 460 w/42" bar milling, got a couple o them in there 2 and other stuffSomething ate the gear up.
