What's on your bench?
Wolverine
dilligaf
4:37 AM
Cutting blades for a print rolling machine... ???
I have experience with sheeters. The blades I’ve used are pretty hefty rectangular shape. But, they’d have to have a chit ton of holes down each one for adjustments. Pain in the arse they are! Set with tissue paper.
beaglebriar
The Peanut Gallery
4:37 AM
Warren Center, PA
Anyone know what these are? 39 3/8” long 1 1/4” wide 3/8” thick. Say Tyzack Machine Knives LTD. Sheffield England.
I have 10. Any idea of what a useful purpose besides making knives?
@sunfish View attachment 153823
Could be sheeter or chopper blades. Both of those have a shallow angle on the cutting edge. At least the ones I deal with anyway. Planer blades will have a steeper angle.
Most are high speed steel and can be repurposed. The cutting edge on my tractor bucket is a Polar shear blade. You don't wanna wack your shin on it you'll be leaving some behind. Lol
4:37 AM
They likely ran the 441 low on fuel and kept trying to start it and it went into "rich protective mode" like it does for an air leak. Hold the throttle all the way open and pull the rope, I'll bet it will start.
Unless you can get it "re set", it will take a several tanks of fuel to fix itself.
4:37 AM
Bought my boy a carb kit for his HU365sp. It’s been a bear to start lately so we figured a diaphragm. Just noticed the choke plate loose so it probably wasn’t closing tight.
Lucky that screw didn’t come out and destroy the cylinder.
mdavlee
Hillbilly grinder
4:37 AM
TN
Got a little laugh just now. Stihl guy dropping off 2 saws 026 441.
Holy heck are the mtronic 441 known hard starters? I pulled and pulled and pulled and pulled and pulled and pulled. Jeez freaking whiz if my poulan acted like this I would be pizzed. I showed the guy my 70.7cc poulan on the bench and it fired off 1st dang pull. crazy right and hadnt been started for a week maybe. Dropped off PHO
If it has a bad solenoid it could be. Should fire up pretty quick from the ones I’ve seen and owned
mdavlee
Hillbilly grinder
4:37 AM
TN
LaRue 10.5 and 14.5
I run a 3 digit serial number 1st gen Noveske lower, New Frontier ultra light upper. Other build is a ultralight tester lower and a matched billet upper.
Nice. I have a Noveske Chainsaw upper with a 16” melonited barrel lead farmer wanted to try with ALG rail and Noveske flaming pig flash hider. I was going to go 13.7” barrel and pin the pig, but I got talked out of it. It’s a poor mans SBR.
4:37 AM
Interesting observations here. 038M vs 262 Husky. 52 vs 48mm. Same stroke as well. Hmmm....
This 52mm jug is AM, but an OEM one has been found for the experiment once the calculations and measures are fighured out on the junker jug.
9C16AC65-3E99-4E7F-B22A-AFFB6B990841.jpeg BECBD102-A36C-4701-A137-23A839D5E778.jpeg 8A3C2422-0A31-4F99-B5BC-204ABDA8B19F.jpeg 81519A60-30DE-4945-B1E0-69E0C3441311.jpeg 85532970-EE4F-404F-B552-0068A9D98922.jpeg
Duane(Pa)
It's the chain...
4:37 AM
Centre County
