What's on your bench?
Genius
First member of ASlite to receive a infraction
2:38 PM
Uncle Willys basement
Thats a expensive pastime ...What do you make of the situation ?
One was a 357 that the auto decomp line melted.
Another one was due to cheap Walmart oil I'm guessing. It passed pressure and vac upon initial checking.
I am not sure about this 575, I haven't dug into it yet.
I forgot about his 394 that was run with to small of screws in the support bracket and the muffler bolts worked loose and cracked the exhaust flange.....
Sty57
1:38 PM
Land of Cheese & Beer
Second attempt to find a Husky orange powder that is close.
I think I'm going to run with it and give it a try.
There all different colors anyway so why not one more.
Glock37
2:38 PM
Monroeville Pa
It looks pretty close do it have a ral number. It may look close in side take it outside in daylight and check Good job
Sty57
1:38 PM
It was close outside, but as you know Mike there all different.
I had four saws outside and everyone was a different shade. It really seems to be a guessing game.
Simondo
7:38 PM
UK
If he keeps busting them I guess you will get the work, so as long as he pays !! Some folks are just plane "Hard" on equipment i find.
Simondo
7:38 PM
UK
The darker one is RAL 2009
The.. RAL 2009 number ...do you know if its a world wide code ? Don't know much about the RAL system and i would be interested to take that info to the Industrial paint makers i use and see what they say.
Sty57
1:38 PM
Most of the powder coat has a RAL number. But I do think it's European system.
I see it a lot for paint codes over there more then in the states.
Sty57
1:38 PM
Liquid paint is much easier to match because you can keep tweeking it until it right.
Powder your kinda stuck with what's out there.
Simondo
7:38 PM
UK
Thanks Gentlemen...thats very helpful of you both. :)
Yup ..wet spray enamel or a machine paint is what I'm looking for and i know "Dulux" and the like have RAL on the Industrial stuff iv bought for Tractors and equipment in the past but iv not had a paint code to use as a starting point . Cheers
Mr.bear
Just hangin
2:38 PM
Indiana
i'm rebuilding a 660 and putting a new head on an vermeer sc252 (doesn't fit on my bench) for a friend. The guy i'm fixing the grinder for got it the other day and apparently the guy that had it befor blew a head gasket and keep running son the head trashed
bigbadbob
11:38 AM
Interior BC Canada
How things have changed, now adays, the damn motor comes out the bottom!!!!
That one comes out either way, but GM does it from the bottom, struts and six big bolts and a few connectors exhaust and stuff, about six hours work.
I have about 25 miles on the engine now and no surprizes, when I first fired it up after about 10 minutes the power steering line blew off coating the entire engine bay with a quart of oil!!!!
Any ways today I am putting the GX390 back on the log splitter, it was smoking bad so did a chinese rebuild,, carb, piston, rings etc $47 bucks,,or about $30 US,
You cant tell the pistons apart,, time will tell.
BBB
ny15
2:38 PM
Lima NY
I have been running the cheap Walmart oil at 32:1 as a test and no damage yet. I was using Yamalube before.
