- 3:34 AM
- Dec 30, 2015
- Georgia
So I put together a 372 clone saw, and all I did performance wise was clean up the castings muffler mod and machine the base to get.020 squish, ended up with 175 psi, but it was lackluster, my stihl ms361 would beat it with the same bar and chain. So it on the bench to get some port work, and a chance to use my new 90° spiny thing. I put my new wheel on it an the numbers tell the story 107/137/75. I was thinking something like 100/122/77, how much compression would i lose going from 107 to 100-102? I did some grinding on the transfers and a touch on the exhaust, I don’t want to kill compression, so right now I am 105/125/75, should I go more or trow it together and see how she runs as is. What would you guy do?
View attachment 132834 So I put together a 372 clone saw, and all I did performance wise was clean up the castings muffler mod and machine the base to get.020 squish, ended up with 175 psi, but it was lackluster, my stihl ms361 would beat it with the same bar and chain. So it on the bench to get some port work, and a chance to use my new 90° spiny thing. I put my new wheel on it an the numbers tell the story 107/137/75. I was thinking something like 100/122/77, how much compression would i lose going from 107 to 100-102? I did some grinding on the transfers and a touch on the exhaust, I don’t want to kill compression, so right now I am 105/125/75, should I go more or trow it together and see how she runs as is. What would you guy do?
View attachment 132839 View attachment 132836 View attachment 132838View attachment 132839 View attachment 132840
Thanks! Will do! Am I better off going to 100/120-122/77-80 or leaving it as is, I like torque, but if it’s better to go another route I am open!!I'd use the gasket as a reference and cut the extension to match the case. And then flare the lowers out to the gasket also. Your current numbers should run good with decent torque. Not high strung
I'd try it there firstThanks! Will do! Am I better off going to 100/120-122/77-80 or leaving it as is, I like torque, but if it’s better to go another route I am open!!
Not familiar with that particular model, but Mac used plugs with sealer to cover the ports, they drilled the port opening on the outside and Then plugged the hole from outsideSo I rebuilt the carb on the Mac 120 for fun because I found a new/old carb kit in the box that it came in. Can somebody explain what these doflinkies r? There's four of them 2 on each side. it appears to be epoxy of some sort.View attachment 132842
Ok so thats the " transfer" port? And it does look factory im sure ur rite.Not familiar with that particular model, but Mac used plugs with sealer to cover the ports, they drilled the port opening on the outside and Then plugged the hole from outside
Nice. Looks the same. What cc is that?. I got a kart here with a honda 5hp on it. Would be cool to put something on it that goes 13k rpmsView attachment 132843
This is a Mac kart block, and those are transfers for it
It’s a 125cc block.Nice kart! Kids grow fast!Nice. Looks the same. What cc is that?. I got a kart here with a honda 5hp on it. Would be cool to put something on it that goes 13k rpmsmy kid doesnt reach the pedals yet so i got time. Won't actually fit on my bench but I'll send a picture anyway
It's a requirementMOPAR FTW!
