What's on your bench?
dustinwilt68
Wilt Built Work Saws
6:55 AM
Southwest PA
I respectfully disagree. Yes stock muffler is better at stock rpm but if you run a ported muffler at stock rpm it’ll be slower. Too fat.
Then you are not comparing apples to apples, scientific method states 1 control variable can only be tested one at a time. I saw turning 13,500 will run different then a saw at 12,500, if the goal to test the speed in the cut rpm must be the same.
dustinwilt68
6:55 AM
Southwest PA
If you start changing more then 1 variable how do you know which has caused the increase or decrease?
6:55 AM
Stock one will loose power tuned to the higher rpm of the ported muffler as well. Too lean. Tune em where they like to be. It wouldn’t be apples to apples by not tuning both of them where they run best.
dustinwilt68
6:55 AM
Southwest PA
You have to look at what you wish to find from your testing, do you think how I tune a saw is the same as anyone else? Certainly not, we all pick up on different things. We are talking about a muffler making a difference with different size outlets, sound and pitch will change from just making the hole bigger, a tach is the only scientific way to measure for accuracy
dustinwilt68
6:55 AM
Southwest PA
I certainly agree that testing in the cut would be best to see which produces more power, if booth are tested by the same person, but that won't tell you that the muffler alone is the difference in what you find, if the carb is changed it now has a role in the findings
6:55 AM
If the only thing you changed between cuts was the muffler opening, and tuned for fastest rpm in the cut, there are no other variables
6:55 AM
If you drilled the jets on a stock saw it probably wouldn’t make it any faster. Just less turns out on the jets probably. It uses the same amount of fuel as before. Ported requires more fuel, if the carb can’t handle the changes then you have to mod it.
dustinwilt68
6:55 AM
Southwest PA
Just stating how scientific method works, how do you know that the difference is the muffler and not the carb if you change booth at the same time? A saw turning a higher rpm should cut faster then a slower one, don't think that is the argument here, how big is to big on the outlet is the question as I understood it. More fuel should equal more power to a certain point.
T.Roller
6:55 AM
Southeast, TN
Sure it would
T.Roller
6:55 AM
Southeast, TN
Not true. My 395 cuts faster at 13.5 then at 14
