usmcbuckwild
Buck
- 4:25 AM
- Dec 24, 2017
- NW CT
Lol. Yup. That'll do it. Good find.There are SUPPOSED to be 4 magnets inside the flywheel. I found 2 in place, 1 obviously misaligned and 1 completely missing. Nowhere to be found.
My welds ain’t too pretty. Truth be told, it’s not easy to make nice beads when one is at different angles with different material that are embedded with impurities. Making on flat plate is easy.A grinder and paint makes me the welder I ain't![]()
That’s a @Red97 stainless deflector that nearly ruined every thin metal cutting tool I own. It must be .125 thick and the muffler around .030 thick. I had to cover the two holes,made by the poprivets as well, so the entire procedure was “*f-wordit, gotta make this air tight and not blow through the this muffler”.
I shoulda Tig brazed it with silicon bronze filler rod. Would made for a better look with the dissimilar material thickness.
They make stainless and silbronze mig wire. Silbronze is what you guys should try. I hear the mig wire ain’t cheap though.
You can also change the heat of your MIGs by altering your gas a bit. More CO2 makes more heat, more Argon makes less. Your gas supplier should be able to make you up 80/20 or 90/10 Ar/CO2 for a fine tune. Straight CO2 is cheap and will make your settings hotter than they are. Uglier welds, but the CO2 stays in solid form and a bottle lasts about 8x the time the same size Argon mix bottle will.
That's exactly how I fixed it.What happened Mike? Screw hole enlarged? You melt/weld some plastic string in there?
https://www.rockauto.com/en/catalog...,5.4l+v8,1433355,body,headlamp+assembly,10762
For about $50, I wouldn't even bother...
Once you have it finished with 2000 grit buff it like a paint job. Then wax it and treat it like a painted surface. It works good, and saves you some money.https://www.rockauto.com/en/catalog...,5.4l+v8,3015249,body,headlamp+assembly,10762
For $186/200, I will bother
That's what I do also.Once you have it finished with 2000 grit buff it like a paint job. Then wax it and treat it like a painted surface. It works good, and saves you some money.
