- 6:07 AM
- Jan 1, 2016
- Warren Center, PA
Chrome rings would probably be more suitable in a cast bore but the cabers will be better than what you have now.
Do You know any on-line source that will ship to Europe where I could purchase Chrome rings?Chrome rings would probably be more suitable in a cast bore but the cabers will be better than what you have now.
I believe they oil through the adjuster holesPicked up a Husqy 240e; needed fuel lines and primer bulb. Someone robbed the muffler, sprocket cover and top cover off of it.
Someone gave me an older all plastic Homelite. Pretty sure the crank seals are bad. It has an odd bar on it; no oiler holes. WTF???
Thanks, really looking foward to having them done, and being pain free.Sorry to hear about your fall. Hope your feeling better soon.
And get those Stihl's fixed up lol
Might need to add a link to all of the chains that you run on that MS170In the meantime I ordered a part for my MS170.
It came in and I put it on.Below is a before and after pic. Cheap mod but worth doing.
View attachment 113808View attachment 113809
My dad is checking one of his machines, starts, idles, takes high idle, but is low on power - powered by a Sachs Stamo 96 2-stroke engine, 1cylinder, 90 cc.
Cast iron cylinder, aluminum cylinder head, no gasket, no signs of leakage, closed port fed.
I told him he need new piston rings, he wants to reassemble the engine as is.
Lots of blow by.
View attachment 113716 View attachment 113717 View attachment 113718
The cylinder bore looks impeccable, the smearing is how my dad checked for ring wear.
He smeared grease into the bore and rotated the crank so the piston goes once up and down - shows where the rings touch the bore and where they don't.
Now, I have a question.
Given that the cylinder is iron not aluminum, can I still go ahead and place regular Caber piston rings in this engine?
I came up with 52mmx2.0mm and the Greek on eBay has these listed.
Do I have to pay attention to anything else than ring diameter and width?
Any help, opinions and suggestions are appreciated, thank You!
52.5mm over bore is what I found, would need cylinder honing - dad won't do that because the cylinder looks very good.Ebay Germany you can find spare pistons.
