Glock37
- 7:14 PM
- Dec 31, 2015
- Monroeville Pa
372xp case
from a severely failed bottom end. Sitting for a long time with lots of baked residue accumulated around the bearing seats and in the case bore between the bottom of the bearing seat and seal. Main bores seem fine, though I'll still do a little surface cleaning with some 20 micron lapping paper.
Otherwise, I'm looking for suggestions on how to clean up the baked on crud without gouging or scraping the adjacent surfaces..., which pretty much takes a Dremel out of the picture. Was thinking about using a socket of the appropriate size and gluing some 320 grit paper to it/trimming it down to size and gently working the area? The halves are in the USC right now and I'm hoping the crap may loosen up a bit after some agitation. The gasket remains are really baked onto the case halves, too. Hope they loosen up at the same time.
TIA for any recommendations.
USC with heat good cleaner then blast and powdercoat is the best for that
Dont go crazy where seal goes
Where bearings are scrape it out gently too
