- 3:37 AM
- Dec 28, 2015
- Central Ohio
I know I'm a newb and this is a dumb question, but if everyone is deleting base gaskets and taking material off the base to tighten the squish what purpose is it to cut squish bands to then make the squish larger again?
How can you tell the 100cc version from the 110cc?The first of my Solo Twins finally went back together this week. I have a second one that has the very rare 110cc topend. I'll be doing it ASAP while the assembly is all still fresh in my mind. This one took about 12 hours to figure out and put back together!
My great friend Rob stopped by to see me, so he got the honors of firing it up for the first time, since I'm recovering from surgery.
You have to measure the bore. Did you get one?How can you tell the 100cc version from the 110cc?
Pure music!!!The first of my Solo Twins finally went back together this week. I have a second one that has the very rare 110cc topend. I'll be doing it ASAP while the assembly is all still fresh in my mind. This one took about 12 hours to figure out and put back together!
The aim is to create squish of about .020. If it is too loose, the engine is not as efficient, if it is too tight it may blow up when it gets hot and expands.
Often, deleting the base gasket alone will not produce the correct clearance. Also, porters often want to take more off the base to get the ports where they want them. They then cut the squish band to get back to approx .020.
i got one the day of the ohio gtg this spring, julie won it on eBay while we were running chainsawsYou have to measure the bore. Did you get one?
Send me the info please, the one i bought ends up being an old model without many of the tools I was expecting.Should have said something. Know a guy selling one in NY.
I remember that now.i got one the day of the ohio gtg this spring, julie won it on eBay while we were running chainsaws
any idea what the two bore sizes are?
