What's on your bench?
Homemade
8:47 AM
Wisconsin
Which flywheel would you use. This one is missing a fin
And this one is beat up
My vote too is for the missing fin. I snapped one off one day, I cut the one off the opposite side to keep the vibrations down.
Chainganger
7:47 AM
Minnesota
261 tank first pic.JPG 262 piston.JPG Husqvarna 261 rescued. Huztl 262 p&c with 12 mm Wiseco circlips (no ears), caber ring, oem wristpin bearing, new crank bearings and seals, new fuel line and filter, new oil line, carb kit and "new" used tank
base gasket delete (squish .019) and muffler mod. The flywheel hit the side of jug and had to be sanded down.
8:47 AM
Luckily, creating a youtube account is free. Did mine on the computer. Tough to figure it out at first (I just started trying different things). I think it was an up arrow near the right that I use to select the file from my computer, then after it loads you must hit the "public" button that is also on the right, then you can play it, copy the address, and share! (Caution ... my method works, but may not be the best way to do it). I just tried things till it worked.
