What's on your bench?
Tor R
Novice, Leg model #2
11:57 PM
Mandal
I got this freebie for a month ago, Husky 42 special year 93, needed a new case.
And cleaning......
My spare case had one issue...cracked guide pin.....wasnt easy to get out the guide pin, done it once I learned the lesson. Easiest way is to slide in an M5 screw, put it is a vice and tight good, then heat and brute force and out it came lol
We got so far today, nightime for old Norwegians...
Work for tomorrow, muffler modds, porting, airfilter modd, and hopefully a start up!
Some music for your lads, RHCP and Frusciante:
5:57 PM
image.jpeg image.jpeg image.jpeg image.jpeg Nothing wrong with how this 930 ran, but that's why I took it apart ;). No porting but did a few mild things to wake it up. Check out the hackjob the previous owner did to fix broken flywheel pawl stop. I don't trust that at 13k rpm. It got replaced with a 910 flywheel that is identical. image.jpegCheck out the size of this flywheel. Giant for a saw. 056 magnum 2 for scale behind it.
Onan18
OPE Sponsor
5:57 PM
Georgia
got a 2252 waiting on parts. jred wanted 160.00 for a piston. got one from red barn for 40.00. waiting on cylinder gasket.
do you know if the jred 2252 came with rtv on the cylinder gasket from the factory?
Cylinder kit is cheaper than an OEM piston, 577 76 47-05 550 top end $121.99
backhoelover
I like tools
5:57 PM
lincolnton nc
i was jsut looking at that. cylinder is perfect. just need a piston. unit has 40 hr on it. i get some pics as soon as i get the cylinder gasket
4:57 PM
Not RTV, but motoseal is used. Its gray in color.
Sty57
4:57 PM
Land of Cheese & Beer
I'm curious on how them pistons look. Can you give an update on when you get one.
I see Meteor lists one for the 562 but not the 550 yet.
