Redfin
Meh...
- 4:46 AM
- Dec 24, 2015
- Central Pa
Makes muh head spin, all those ports.I hate not being able to fall asleep so I dorked with this 261 a tad. Pulled numbers and stuffs. Interesting piston and tiny little intake, stratos play a large role in the volume of air moving into these.View attachment 58119View attachment 58120
I gotta try one.
@Redfin
Do you need to buy new bolts for reassembly?
Are those models the ones with the new fangled torque to yield fasteners?
Me too. John are you going to work with the stratos? Or gut them?
What did you get for stock numbers?
The only bolts you need to replace on those are the aluminum crankcase screws. They're a one time use. The screws come with if you buy bearings, crankshaft or crankcase gasket.@Redfin
Mark never heard of stuff like that , wonder if we can buy it here in AustraliaLooks like it was not properly cleaned before the RedKote. I have had some POR come off but not RedKote.
Just make sure you give it plenty of time to cure completely before adding fuel.
Mark
thanks Mark , , they wont post that for sureI believe the solvent used in it is MEK (methyl ethyl ketone) so shipping is generally a challenge. Good stuff though.
Mark
why did you use itthanks Mark , , they wont post that for sure
why did you use it
Peter
Good to know. I had first heard Randy mention something about one time use bolts in the new model to save weight. Wasn't sure where they were. Now I know.The only bolts you need to replace on those are the aluminum crankcase screws. They're a one time use. The screws come with if you buy bearings, crankshaft or crankcase gasket.
very smart, never seen a leak test done like this before , how much air did you put in psiNarrow down airleaks on an 550, sometime dramatic solutions work out best
The big bubble test:
Went fine, leak around my homemade head gasket, and one leak around one of the vac/pre test kit plugs from Husky.
Gone flush the oil tank after this![]()
Never seen a skid plate on a saw befor. Kinda cool.Sending the warranty ms180 out the door tomorrow......having issues with an 026 as always......and installed this skid plate on my 441. View attachment 58067 View attachment 58068
15psi, its probleby an hour since I started and its down in 11 psi now, Husky recommend 12 psi.very smart, never seen a leak test done like this before , how much air did you put in psi
Peter
