What's on your bench?
Woodwackr
1:37 AM
ID
TheDarkLordChinChin
My name Borat, I like you
8:37 AM
Ireland
My 2018 ms462 died exactly a year and 2 days ago.
The decompression valve came flying out on a frosty morning while the saw was cutting big ash.
Since the evening of that day the saw has been sitting in my friends shed. He's a man in his mid 70s. A very eccentric fellow who is a trained heavy diesel mechanic and a more than competent small engine mechanic. In fact, he was the original mechanic at the local stihl dealership, he helped them set up their business and worked there for 25 years before retiring.
I want to get my saw back running, I've waited for him to fix it for over a year now so at this stage I'm just going to do it myself.
Our original plan was to heli coil it, which I have little orno faith in. Time certs are another thing I've heard of but don't know what it is.
Really and truly the best option is a new top end. I can get one from Poland for 350 ish or from Greece for a bit more. There's no point trying any of the dealerships here, it will take them months to get it (if they even remember to order it at all) and then they'll charge an arm and a leg for it.
If I'm not mistaken didn't stihl change the 462 a bit some time ago? Will a new top end fit my 2018 saw? This is the one I'm looking at but there are others available.
eric4
12:37 AM
Northern CA
What do y'all think about the recoverability of this cylinder. The dings on the food bother me less than the plating around the exhaust being chipped.
Woodslasher
Teh debil
12:37 AM
Commiefornia
eric4
12:37 AM
Northern CA
Looks done 😕
Any damage to the rest of the cyl walls?
The walls are clean as can be, and the roof dings don't really seem to protrude downward... But the damaged exhaust seems the most concerning. I figure it wouldn't hurt to try opening the exhaust until the plating damage is ground away? Seems like 1/16" above and below would clear it up.
hacskaroly
2100 Fanclub Member
12:37 AM
Northern Idaho, Ehh
I have a cylinder that has those dings and some of bits of the ring still embedded in it...lol
Woodwackr
1:37 AM
ID
As suggested, then, the cyl could be ported. Or, at the least, the ex port can be re-beveled.
SimonHS
8:37 AM
Yorkshire, England
Might be cheaper to send it to @srcarr52 (Shaun Carr) and ask him to weld up the hole and re-cut the thread. Or leave it welded up and delete the de-comp.
Was the stripped de-comp the only damage?
I don't think a new version cylinder will fit on your saw, so you will need to find an early version or fix the one you have.
srcarr52
3:37 AM
Iowa City
I don't think a new version cylinder will fit on your saw, so you will need to find an early version of fix the one you have.
M10x1.0 helicoil is the best option. They really work well for that small thread pitch and the outer diameter of the repair coil is less than the sealing crush washer of the decomp valve.
TheDarkLordChinChin
8:37 AM
Ireland
That's another good idea, thanks. Yeah I think that's the only damage but I'll have to look at the saw again to know for sure, it's been over a year since I seen it.
I don't trust heli coils. It seems to work if the right man does it but I don't know who that is. A friend had a heli coiled plug come flying back out on a 462 that was repaired by the best saw mechanic around here.
eric4
12:37 AM
Northern CA
I've got a 562xp (2258) on the bench today, that has corrosion in the crankcase unfortunately... It seems to be interfering with the crankshaft balancer (counterweight?) as it moves along the bottom of the case. It still rotates fully, but definitely has some drag when it apexes the bottom, and seems to be on just one side.
Is there a method to clear this up, outside of splitting the case? The only ideas I could come up with inside my empty noggin, is to lightly grind down the balancer until it clears the case...Or glue some emery cloth to the crank and rotate it until it clears up the case corrosion.
Partner
9:37 AM
Poland
It will also make room for itself while you work
av8or3
3:37 AM
Waleska,Ga.
+1 on the heli-coil. I’ve had perfect results with them. I keep them in about 4 sizes.
Partner
9:37 AM
Poland
I don't have these knobs for the heli, but I screw them in with red glue using pliers
