What's on your bench?
markds2
6:02 PM
Nelson, New Zealand
av8or3
2:02 AM
Waleska,Ga.
Another FoggySail ignition repair on this Dolmar 123. You’ll notice the kill wire has been clipped and covered with epoxy, and used for the wire out to the capacitor. I’ll run a new kill wire from the + side of the cap to the kill switch. It seems a bit simpler.
I sure am glad I know how to do this. About every other one I acquire requires it be done. Makes for a nice mannered reliable saw after.image.jpg
Woodwackr
12:02 AM
ID
I rebuilt and used the 228 carb from the 281 carcass to get the 288xp going. Sounds like a beast 😁.
Do these carb have a governor? Sure sounds like it at wot.
Tried uploading a vid...no joy
Still need a clutch cover or just a flag that works with this wrap handle
Duce
2:02 AM
Roscommon, MI
View attachment 416363View attachment 416364
Do you mean it’s hitting ignition module limiter?
Woodwackr
12:02 AM
ID
I think so but not having any saws with limiters I’m not sure. If not, then there is another issue :p
So, the OE 228 carb doesn’t have some sort of limiter?
How do I post a vid on this site?
Maintenance Chief
2:02 AM
South Carolina
Some of the 288 carbs did have a governor, idk which ones?
Woodwackr
12:02 AM
ID
It ran much smoother today. Probably took a while to burn off all the assembly mix oil :p
Just need a clutch cover or flag.
I’m going to throw an old Ore 31” bar on it outfitted with some of the 43RM I have…404, .050, comp, semi chisel
Stay tuned…
Anyone want to try this chain, let me know…can make up a loop.
Powerstroke Cowboy
12:02 AM
Montana
pbillyi69
11:02 PM
USA
i got my worm drive skill saw at the hawk shop for 15 bucks. cleaned it up changed the oil and looked it all over gave a new blade. if i remember correct the blade was more than the saw. it works great the brushes looked pretty new.
