Maintenance Chief
- 1:06 PM
- Jan 4, 2020
- South Carolina
No the good poison ones.Are they made of the green rubber ethanol friendly?
Maybe it comes from people pinching the bars and jerking on the saw, just a guess.I bought two 353's on seperate occasions and Both had that AV limiter area broken off. Not exactly glad that it is a weak point but at least i'm not alone i guess.
That is correct, but non ethanol is readily available around here, a few of the marina stations have high test also.Every fuel line and impulse hose should be Ethanol friendly.
It's up all the way and I'll pull it off. Just a pin to remove.Don't forget to raise or remove your trailer jack wheel.
Sent from my SM-N975U using Tapatalk
Those have a limited coil so don’t go by how it sounds. Tune in cut, 1 turn out should get you close.View attachment 265825
As I posted earlier, I was waiting for new OEM fuel/ impulse lines to come in for my scrap yard MS441 and was glad I did as the original ones pretty much broke apart while removing them a second time. View attachment 265826 View attachment 265827 View attachment 265828
Well she's all together now, and running. I made a few test/tuning cuts with a 25" bar and it pulls nicely.
I have never had a carburetor with the limiter caps still present for this saw though so I'm also puzzled what the initial setting would be from seated?
Thanks, I appreciate the information.Those have a limited coil so don’t go by how it sounds. Tune in cut, 1 turn out should get you close.
South Carolina, is probably the last vestige of free wheeling America that I found. People are ridiculously nice and polite here but don't tell them how to live or you'll get a blessing! LolI think you are the minority, not the majority.
Tennessee is same way.South Carolina, is probably the last vestige of free wheeling America that I found. People are ridiculously nice and polite here but don't tell them how to live or you'll get a blessing! Lol
Not on the bench anymore, but here is the end result of a box of parts courtesy of Lehman Live Edge Slabber. I used some of the parts on a repair job and the rest to put this one together to go in the museum.
Mark
It's the same where I live, SE North Carolina.South Carolina, is probably the last vestige of free wheeling America that I found. People are ridiculously nice and polite here but don't tell them how to live or you'll get a blessing! Lol
Trying to find some timing #s on this 440
