What to do with a ms250
idiotwithasaw
10:19 PM
Ky
025= 42mm bore
Ms250= 42.5mm bore
Hedgerow
10:19 PM
That's what I was thinking.
Both need more carb.
By whatever means necessary.
idiotwithasaw
10:19 PM
Ky
I do have a question was there ever a time when they were a dual open port, I always thought they were quad open ports but I have one that looks like a ms250 but it's a dual port. Very confusing.:eyepop:
Hedgerow
10:19 PM
025 was a dual port open.
Hedgerow
10:19 PM
Look at the ex port, then follow the path to your outlet.
czar800
11:19 PM
Ellwood City
Maybe I'll put the wheel on it...... And just clean things up..... Ok remove just a little.......
Anyone want to share some #s? I have a wt215 carb ready. It that enough carb?
Brian Simonseth
CANCER AND STROKES SUCKS
8:19 PM
Stanwood, Washington
Cut the center of the baffle out
Make a hole straight to the hole in the inner section of the muffler
Hedgerow
10:19 PM
Put the wheel on it..
In. 163
Ex. 166
BD. 15
215 will function great, but leaves a lot of performance on the table.
Need to tidy it up a little.
David Young
Safety First !!!!!!
11:19 PM
vt
In. 163
Ex. 166
BD. 15
2 or 4 port?
Magic_Man
Oh Yea !
11:19 PM
SE Ohio
In. 163
Ex. 166
BD. 15
Did you do anything with the squish ? I have heard of guys welding pop ups but also milling the jug and recutting the bearing pockets.
Hedgerow
10:19 PM
In the past I have. But was not worth 10 pounds of comp and heavy piston.
Just make it a better pump and it'll produce more rpm's and power.
Ex. is high on the 025's. I'd be interested to see if stihl lowered it on the 250's.
Hedgerow
10:19 PM
@Hedgerow
He grinded on an 025. It rips with a nice chain. Based on what I have seen with his, yes, it is worth grinding on.
Thomas, do you have any vid of Sam's 023 or Levi's 025 racing?
I can't find anything.
David Young
Safety First !!!!!!
11:19 PM
vt
I think I have the numbers written down in my shop.
