3browns
9:38 PM
Fishhook, Alaska
I would love to see a picture of the entire saw to see if the paint on the bar was toasted as well
The whole damn saw would have been smoking
I guess it could be operator error but man oh man, if it was this is some short bus stuff right here.....
3browns
9:38 PM
Fishhook, Alaska
So are we back to some sort of fuel related cause?
The repetitive nature of the damage kind of rules out part failures I would think
Or are we sticking with "operator headspace"...
bwalker
1:38 AM
Montana
Air leak induced lean question would be my guess.
bwalker
1:38 AM
Montana
Of all the seizures I have seen only one could be attributed to fuel and that engine was very marginal for pump gas compression wise. The rest were caused by lean conditions as a result of mostly air leaks, but some times temp.
Given the low compression ratios of saws I would wager that just about all burn downs are a result of air leaks or severely lean carb settings. Even with really lean carb settings its tough to burn a saw down.
junkman
Crush it
10:38 PM
pacific northwest
You left out operator error ,some people should not be around 2 strokes.
danimal
12:38 AM
Armpit of da Midwest
Or..... they don’t
Xactly. Idiots tear chit up and clueless as to what happened.
Like a fella rented da house across da rd couple winters back.
Was using bar oil for his 2stroke mix.
( hey! why aint this saw running like it was last wkend)
Ya cant fix stupid.
Which these new puter saws are, by the way.
Wood Chopper
So so sleepy....
1:38 AM
Mechanicville NY
So let me ask a question That I’m sure has been brought up more than a few times elsewhere how important is the flash point of an oil. I’m running Amsoil saber at 40 to 1 contemplating going to something with the higher flashpoint like Motul 800 2t. I’ve never had a problem so I should probably just leave well enough alone I just think it’s interesting
Deets066
AKA Deetsey
1:38 AM
Motul 800 doesn’t burn very well in a saw
1:38 AM
I think the Klotz Benol would do better with high heat.
