damifino
1:55 AM
NW Indiana
Rotella T
Several years ago my son started riding Yamaha yz250f dirtbike. I started using Rotella T 15w40 non synthetic after reading so many good reviews. Inside of engine always spotless. Affordable too.
smokey7
2:55 AM
Detroit
The rotella oil my family has the most experience with is Shell Rotella. Now called T4. Ive personally seen 130hp turbo case tractors burning a few qts of oil a day doing hay and silage with valvoline, delo, mobil, gulf and others. Then switch to rotella and oil consumption go way down to a quart every 50 hrs. Thats a huge difference. On the farm we have several tractors with 6,000 to 18000 hrs and finally had 1 lost a turbo last year (compressor wheel blew apart). Thats not a oil issue tho. Several trucks with 300-500k on the clock and still not using any meaningful amount of oil. I remember a few years ago we bought a JD 2940 with 5500hrs. Engine was hammering bad. We rebuilt it had crank turned all new bearings new pistons, rings, liners and all. We ran it for a couple years then decided to sell it. Engine never burnt oil with us when we sold it to a local farmer with a 12 month engine warranty. The guy came back after a couple hundred hours and a oil change complaining about oil use. He switched to his favorite oil valvoline. He said he was using upwards of 4 qts a day running a silage bagger. He said something had to be wrong. We changed oil and filters back to wix filters and rotella oil use went back to nothing worth mentioning. He was shocked, i was also when i cut his filters apart and saw glitter. I still had the filters from the pm when we sold it (no glitter) i had him bring me the next pms filters back and there was tiny tiny amount of glitter (probably leftover from his valvoline pm) long story short i feel that rotella T4 is my oil of choice for diesels. I have no experience with any of the other rotella diesel oils tho.
2:55 AM
Which Rotella had the less than desirable UOA ? The dino , the syn blend or full syn ?
Rotella synthetic oil. I have been out of the loop on their wording. Maybe called Rotella T? 5W40 oil.
Flatzout
2:55 AM
Kathleen , FL
Maybe the duramax didn't like rotella , it happens. Certain engines do better with certain oils. , that's the good thing about doing UOA's , to find out which one works for your particular situation.
I've run SOPUS products forever it seems , never had a failure do to engine oil (knock on wood).
My last oil change in the truck I went with Mobil 1 high mileage , it seems to run pretty good. I won't run anything but a Wix oil filter.
2:55 AM
It will be a while. I only change my oil once a year. That's in July, so I run it for one year. The by-pass oil filter really helps. My UOAs show I could get more out of the oil, but I always act on the safe side.
I will report back when I get the results.
Iffin I ain't banned by then.
1:55 AM
I need to run some of this in my pos Honda.
Marshy
WFO Cutting
2:55 AM
Mexico NY
You have a bypass filter? Is that a custom made filter?
Ron660
1:55 AM
NW Louisiana
is this after 1000 hrs. if not it don't mean swat
I doubt it. I've seen the inside of saws with a lot less hours than that on other brand oils, 50:1, that failed. Most Loggers in my area their saws last less than a year. Might be more contributed to the quantity of used not the brand.
jakethesnake
I Am The Snake
2:55 AM
Here & Now
Have you ever had any UOAs done on your fleet oil? Have you compared Rotella to sny other oils?
Nah. But I have over 10000 hours on the stuff on one single piece of equipment. 4000 on others. Million plus miles on some of the tractor trailer trucks. Other tractors with 10000 hours plus. Since switching to Rotella oil consumption went from a gallon every few days to you just don’t have to check it. I still do check but it’s always full. Even when things are overdue for a change. Good oil for big diesels. *s-word I use it in my pickup which is gas. I have a barrel of it so I use it for everything
2:55 AM
My vw burns about 1/2 quart or less every 5000 on the 5w40 oils I’ve ran in it. A touch more with the thinner 0w40 Mobil 1 as expected.
2:55 AM
The detergent in dino Rotella T 15w-40 dissolves carbon better than any oil I've ever noticed. We've had a few cars in the family that had high mileage on them and started to burn some oil. After a couple changes of Rotella T in them they actually stopped burning oil. Same thing goes for small Honda inverter generators. They end up burning oil after a while and one change of Rotella T in them and they quit
Roadfxr
1:55 AM
Iowa
All we run in our water pumps and generators at work is 15w40. Mostly Rotella and Schaeffers. I’ve got one water/trash pump that the seal went out on between pump and motor and has been running 15w40 milkshake for at least a month. It started as a let’s just see how long it runs til it blows. It just keeps going and going. Who knows....
