porsche965
- 10:33 PM
- Jan 13, 2016
- N.E. Ohio
Those pics look great RedBull. What are you paying for the Schaeffers? Thanks.
I've changed about 20-25 cranks in the last 5 years in saws they told me were run on 50:1. Never had changed one from someone who said they run more oil. Also had around 8 sets if cases that were trashed from spun bearing s or pockets beat up. Not sure any correlation between that but it was the same crews.We should take a poll on bearing failures documented due to lack of oil and the ratio of oil the bearings were run at. It would support your thesis.
Is this why Husqvarna is beefing up their bottom end of the new 572xp so they can still comply with the EPA @ 50:1 without further failures?
There is some truth to that. However more oil helps seal the tings better and provides for a cleaner engine IME.I don't know. I will repeat something that @tree monkey Scott has told me a few times.
He doesn't run 32:1 so much for the film of oil between the piston and jug. He says you really don't need that much. He runs 32:1 because of the bearings. Those are what need the most oil.
Anyone thats been running saws for awhile has noticed that the motors are using less fuel and as a result oil now than they did back in the 90's. Strato charging makes it even worse as those motors likely are less lubricated at 32:1 than an older saw was running 50:1.We should take a poll on bearing failures documented due to lack of oil and the ratio of oil the bearings were run at. It would support your thesis.
FWIW that oil is formulated exactly like a TCW3 marine oil. Schaeffer actually suggests it be used in boats amongst other things. They also claim that it "meets and exceeds" tcw3,jaso FC and ISO EGD. From a technical standpoint this simply is not possible. If you dont beleieve me try to find an oil on the jaso FD list thats also tcw3 certified.Ran Schaeffer 9000 full synthetic on a new 661. 32:1 for 12 tanks running 36"-41" .404
This is NOT the tcw3 7000 semi syn.
Can you explain why a strato engine would be lubricated less .I have a 441 and looking at the piston with muffler off when i changed the muffler ,the piston was wet with 40 to 1 saber .I am not saying they aren't i just don't understand how the strato stuff works .Anyone thats been running saws for awhile has noticed that the motors are using less fuel and as a result oil now than they did back in the 90's. Strato charging makes it even worse as those motors likely are less lubricated at 32:1 than an older saw was running 50:1.
H
Pretty simple. They use less fuel, thus less oil moving through the motor.Can you explain why a strato engine would be lubricated less .I have a 441 and looking at the piston with muffler off when i changed the muffler ,the piston was wet with 40 to 1 saber .I am not saying they aren't i just don't understand how the strato stuff works .
Seems the main goal of EPA is to put less pollutant into the air so that kinda speaks for itself?I had a guy argue with me over that. He said you're still using the same oil and gas.[emoji848]
The EPA is Hypocritely funny.Seems the main goal of EPA is to put less pollutant into the air so that kinda speaks for itself?
Yes. The diesel trucks are a big fail. Got from 16-20 to 11 but it's cleaner they say. At least now with DEF fluid they're back to pushing 20.The EPA is Hypocritely funny.
Ed ZacharyYes. The diesel trucks are a big fail. Got from 16-20 to 11 but it's cleaner they say. At least now with DEF fluid they're back to pushing 20.
Of course. The US and EPA has a war on dieselsEd Zacharyand funny thing on diesel and the scary NOX that comes out of them. I was reading a test that was done for the BBC. They had a 5 year old diesel car vs a 15 gas car. The gas car was like 10 times dirtier lol.
H
paid $45 for the gallon I bought of the 9000. The 7000 semi syn IMO runs even cleaner but people get hung up on the "tcw3". Yet Scott has ran the 7000 for the last 20 years in every 2 stroke engine he has. Swears by it. Place I got the 9000 for $45 had the 7000 for like $28 for a gallon.
I see Amazon has the 9000 for $56 shipped.
http://www.schaefferoil.com/retail-locations.html
I think the 9000 would handle more heat better. So I guess my plan would be to run the 9000 in ported saws and 7000 in non ported saws. Or the 9000 in any application that really pushes the saw like long bar or milling.
I would choose the schaeffer over the amsoil saber. pics attached 15 tanks on new 661 with saber 32:1
