Keith Gandy
Maxima K2 40:1 87 Pump Gas
1:14 AM
Provencal, Louisiana
Big words with no real world differences
Bull! Alot of difference in thoso 2 oils. If u want a cleaner auto engine do u run regular or super? More additives to clean the engine. More cleaners and anti friction additives in RA vs Powerblend. Find another OPE oil that has all thoso
Keith Gandy
1:14 AM
Another component that RA has that Powerblend doesnt -----Ester Chemistry
In many ways esters are very similar to the more commonly known and used synthetic hydrocarbons or PAOs. Like PAOs, esters are synthesized from relatively pure and simple starting materials to produce predetermined molecular structures designed specifically for high performance lubrication. Both types of synthetic basestocks are primarily branched hydrocarbons which are thermally stable, have high viscosity indices, and lack the undesirable and unstable impurities found in conventional petroleum based oils. The primary structural difference between esters and PAOs is the presence of oxygen in the hydrocarbon molecules in the form of multiple ester linkages (COOR) which impart polarity to the molecules. This polarity affects the way esters behave as lubricants in the following ways:
Volatility: The polarity of the ester molecules causes them to be attracted to one another and this intermolecular attraction requires more energy (heat) for the esters to transfer from a liquid to a gaseous state. Therefore, at a given molecular weight or viscosity, the esters will exhibit a lower vapor pressure which translates into a higher flash point and a lower rate of evaporation for the lubricant. Generally speaking, the more ester linkages in a specific ester, the higher its flash point and the lower its volatility.
Lubricity: Polarity also causes the ester molecules to be attracted to positively charged metal surfaces. As a result, the molecules tend to line up on the metal surface creating a film which requires additional energy (load) to wipe them off. The result is a stronger film which translates into higher lubricity and lower energy consumption in lubricant applications.
Detergency/Dispersency: The polar nature of esters also makes them good solvents and dispersants. This allows the esters to solubilize or disperse oil degradation by-products which might otherwise be deposited as varnish or sludge, and translates into cleaner operation and improved additive solubility in the final lubricant.
thomas1
┌∩┐(◣_◢)┌∩┐
2:14 AM
Cristobal Colon
Wait till I get my FLIR gun and start testing underpants [emoji106]
I'm very interested in these results, I have a friend who often tells me about his "hot sharts", butt it would be nice to log the results on the backside.
Joe Kidd
I reckon so
2:14 AM
NC
Yep. Theres big difference in makeup of oils if one takes the time to look. All 2t oils arent equal. RA also has more highly refined bases vs Powerblend
Here's a better highly refined base.:clapclap:
