greystone mountain man
- 12:53 PM
- May 7, 2024
- East Tennessee
It's actually nice when people talk sensibly and aren't crying in their oil jug
This post by @fearofpavement back in 2022 is the best comment about mix oil I have seen.
That's been a well known concept in lubrication for over a hundred years.Actually the latest testing on viscosity in the real world is pointing towards it's very important. Apart from a thicker oil has a better ring seal and producing measurable hp gains, thicker oil also offers superior engine wear protection over thin oils.
There are companies with all the expensive equipment and knowledge testing all this.
Testing also shows once an engine is up to operating temperature any parasitic loss of a thicker oil goes away.
I believe top fuelers run a straight 70-80 weight oil. Whoever said viscosity means nothing is guessing at best lol
50-50 gas and diesel cleans just about anything. I canāt stand people bringing me a dirty as hell saw to repair for them. We ran 30w oil mix in a 1954 25hp Evinrude for years and 12-16 year old boys ran the piss out of it. Never torn it down, because we never had a reason to.Thanks to Randy for his advice on the subject. Mix oil's now the least of my concerns. No engine failures in 5 saws over a decade even with Stihl Ultra, but I wasn't wild about the carbon buildup. Nowadays, I'm focused more on sharp chains, saw maintenance and not getting whacked by widow makers.
BTW, any suggestions for solvents to clean the crap off of flywheel fins & other parts? Air compressor only goes so far. Thanks.
Compared to motor oils two cycle have almost no additive package. If you did juice one up with anti wear additives you would have deposits and pre ignition galore.It still depends on the ad pack. I believe it was mentioned that dominator has a lower viscosity than most oils tested, but it was the one that came out on top because of how clean it runs even with added heat. But generally speaking, if the ad packs were the same, I agree completely with you
What Julian's test proved was that heavy base oil two cycle oils hurt performance of a chainsaw...maybe.Oh no worries, you must have missed Julianās testing and outcomes then. They were all performance related as in actual cut times, I guess they were not valid eitherā¦
In the scientific world that's how it's done. It's called peer review.A ton of stuff could be rehashed, Joe has a saw dyno, but testing costs money, oil, fuel, time, ect, ect. Why do all of it, then publish it here to be ridiculed in the court of public opinion? As far as 2 stroke technology goes, nothing much has changed since the 70ās really except oil. It would be interesting to see if modern oils hit the same 18:1 brick wall as far as performance was concerned. 2/3ās here probably still wouldnāt believe/accept the results. Some would jump up and down and scream ānow just wait a cotton picking minuteā. Sadly, they are the majority and are the ones who are embraced here, not the ones who actually wanted to document/share their findings to help other members.
This sums it up perfectly...There are so many variables that there are very few "facts". We could have a discussion about how these variables skew results. Or we could all just be diks.
i just use gas but 50/50 gas and diesel is probably betterThanks to Randy for his advice on the subject. Mix oil's now the least of my concerns. No engine failures in 5 saws over a decade even with Stihl Ultra, but I wasn't wild about the carbon buildup. Nowadays, I'm focused more on sharp chains, saw maintenance and not getting whacked by widow makers.
exactly.....when my jug of random oils runs out i will get some dominator. im pretty sure there is some of that in my jug currently tooThis post by @fearofpavement back in 2022 is the best comment about mix oil I have seen.
Just imagine if it was full synthetic!
Chainsaws too - stratified was a major step forward. Now look at the Stihl MS 462 - most if the builders would agree, that although gains can be made with these, from the factory they are already pretty āhotā and much different than the saws of 10 years ago.Iām still a little confused about āAs far as 2 stroke technology goes, nothing much has changed since the 70ās really except oil.ā Snowmobiles, for one, completely disagree.
Brilliant!We have one oil with different labels - jet ski, winter scooter, two-wheeled vehicle, chainsaw, boat. etc. to make every owner of the machine feel good![]()
As the power increases, the heat increasesChainsaws too - stratified was a major step forward. Now look at the Stihl MS 462 - most if the builders would agree, that although gains can be made with these, from the factory they are already pretty āhotā and much different than the saws of 10 years ago.
