Sloa
11:15 PM
Canada
placing a dog from a 028 onto a 038 super and it has this black plate, doesn’t seem like it is needed.can someone please explain how dog gets mounted.
pbillyi69
9:15 PM
USA
its either one or the other not both
mainer_in_ak
8:15 PM
Interior Alaska
Relax...I was just saying you didn't hurt your saw from running it a bit lean.
The more I hear about Echos the less I want to own one if indeed they are that finicky.
Oh my, bwalker wow! Yep, thanks for stating the obvious that you can't handle echo saws.
A 1/4" turn on a high jet soooooo challenging, and finicky.
bwalker
12:15 AM
Montana
You're the one who said finicky and weird. I trust you...
bwalker
12:15 AM
Montana
Man, I swear it’s almost like I’ve seen the end of this movie before, hmm…
Its like the movie Whats Eating Gilbert Grape with Arnie/DeCaprio screaming ECHO!
bwalker
12:15 AM
Montana
Ran saber at 32:1 in the fleet of saws for about 18 months. Would never run saber in the oil injected snowmobiles because I was afraid it would strip out the plastic oil injection gears. It's too thick in the hard below zero temps. It won't pour from a bottle at 30 below zero.
The saber residual in the crankcase of 90 cc and 100+ cc chainsaws was so gummy in below zero temps, the saws were hard to start.
Have always ran the lucas 2 cycle in the snowmobiles because it pours at 30-40 below.
To simplify things, I have been running the lucas in everything: string trimmer, ice auger, brush cutter, snowmobile, and all the chainsaws. Switched in February 2024. No stabilizer in the lucas so have been adding 1 oz stabil marine per 5 gal jug.
Dunno if it's built up carbon or shortened lifespan of saws. One saw in particular: a cs 590 has been run only on lucas since new. I'll pull apart the saw in March post up pics of the cylinder at the 1 year mark of lucas.
30 below zero last February:
Why would you use premix oils in an injection system?
