ammoaddict
5:10 AM
Granite Falls, NC
I could walk outside and put some 50:1 Super M in a jar to show the mix color. But then I would have to get up and go out there
Have you tested the super m yet? If so I will go back and look for it.
Sent from my moto g(7) power using Tapatalk
ammoaddict
5:10 AM
Granite Falls, NC
Not yet but there has been an offer to send me a whole ration of oils. I have a couple others here to test b4 getting more and only one other trimmer atm.
Thanks man. I'm really enjoying this testing.
Bilge Rat
5:10 AM
savannah georgia
Had a 4 mix motor that i poured some 32 to 1 mix of K2 in it to check the valve s sealing.
After sitting in the jug about 5 minutes i wiped it out with a rag.
Most of the carbon crud that was caked up in it wiped right out.
Mineral spirits did little to remove the crud.
K2 oozes out of the muffler on my weedeaters unburnt. Inside the motor is well lubed and clean.
ammoaddict
5:10 AM
Granite Falls, NC
When I clicked on that link, my phone tried to dial that number.
Duane(Pa)
It's the chain...
5:10 AM
Centre County
Thank you. So you know, oils tested thus far.....
Motul 800 off-road
Echo Red Armor
Amsoil Saber
Blue Marble - in process
Did you say you tried ATF? I try to keep up but this thread is off the chart now! Thanks a million for your testing and efforts...
ammoaddict
5:10 AM
Granite Falls, NC
I had some odd stuff going on today. I was walking around my property and posting here. Every time id loose my WiFi and phone switched to 4g or back to WiFi, it made me log in again. Couple times i was posting when it happened. Next thing I know i had multiple postings of the same things. I didn't post a link though.
Weird ain't it.
