RalphK
4:18 PM
Left Coast
Old bottles of saber 100:1 used to say for racing or commercial applications run at richer mixtures. Can't remember but I thought it was up to 32:1
lehman live edge slab
Live Action
6:18 PM
Mn
The old 100:1 bottle stuff said up to 50:1 on the stuff I saw. Never seen any amsoil call for 32:1
lilspenny
6:18 PM
I like Saber at 40:1. Runs clean and lubricates well. Not saying it is the best, but there is nothing wrong with it either.
I like the way Saber smells.... better than Ultra, HP2, VP, and Red Armor. Back in the 60's we had one of the first Mercury 100hp engines and that thing used a quart of "Formula 2" for every 6 gallons of Amoco white gas. That smell was fantastic! I remember smelling Ultra and having flashbacks to Formula 2.... made Ultra smell like a burning plastic fork.
Live Action
6:18 PM
Mn
Yes, but mixing the air is not difficult 😉 Maybe otherwise, the air does not reduce the rotational speed wot 😎
Fan doesnt load the engine down enough so it doesn’t over rev and blow up? They designed this to be under this specific load and that’s enough to burn off the oil.
Take the fan off and run wide open and see how long it lasts. Shouldn’t soot up in one tank no matter what oil is used 50:1.
Tomos770
1:18 AM
Slovenija
I'm just an ignorant consumer with 68 years under my belt. I ask you.... if octane does not prevent pre-ignition why does Valvoline say this?...
LOW-SPEED PRE-IGNITION PREVENTION​
While the causes of low-speed pre-ignition are not fully understood, there are a few critical steps one should take to prevent it from happening. That includes selecting high-quality engine oil, high-octane fuel, and cleaning products for a petrol system.
Dont mix TGDi/GDi car engines with OPE....2 differeny worlds....
In (downsized) car engine....especially if equiped with turbo.... ACEA A3/B3 engine oils which are loaded with detergents (Calcium and Magnesium in oil lab tests)....especially Calcium Sulfonate contributes to LSPI phenomenom....
Thats why API SP.....ACEA C1/C2...vw508/509....MB226.?? etc engine oil standards for TGDi engines exist.....and they are usually low Calcium Sulphonate (and Magnesium Sulphonate).....
Search forum as Bitog (Bob is the oil Guy)....
Lions fan
7:18 PM
Cheboygan, MI
bwalker
7:18 PM
Montana
Live Action
6:18 PM
Mn
Cut the strings off on a whip and hold it open then put 16” of string out and listen to the weed whip lose rpm. 2 pieces of plastic string are enough load to change rpm. Now let’s talk a huge fan blade moving a bunch of air through a 4” tube at 200mph
Partner
1:18 AM
Poland
Ok, last question 😉🤭 does the fan have the same battery as other garden devices with a battery?
redneckhillbilly
5:18 PM
NW MT
is there anyway to prove that the husqvarna premix canned fuel actually uses husqvarna mix oil in it, I was thinking about adding some more ouls to get it down to 32:1, but dont want to mix oils.
pbillyi69
4:18 PM
USA
why dont you want to mix oils? if you look up the safety data sheet you might be able to figure out what oil is in it.
