What octane is best, and why
pbillyi69
1:55 PM
USA
i started making gas with the 100ll and 92efree gas no tuning problems and it doesnt bulge the cans either. i use gallon jugs to fill my tools with and had one that was only the 92 and one that had the mix and the one with the av gas didnt build pressure like the other jug did with only the efree. not what i expected. they were in the sun but it was only in the 60s
pbillyi69
1:55 PM
USA
i posted earlier in this thread i think but my blower didnt like the 100ll mixed @40:1 would not tune at all but runs just fine with the 100ll and 92efree mix that i make
jetsam
4:55 PM
Trogdoria
I get along fine with whatever is cheapest at the pump. If you're putting the saw up for storage, break out the synthetics or the fancy no-ethanol stuff. For a saw that actually gets used regularly, whatever's cheap works. Tune the saw for what you burn in it.
BK13
1:55 PM
Oregon City, OR
Maybe this has been mentioned earlier, but if you're going through that much gas that quickly, is E-free necessary? I thought ethanol's big failing is long term storage. both fuel degrading itself, plus the deterioration of seals and such. If you turn your fuel over every couple days, is regular ethanol fuel still a problem?
davidwyby
1:55 PM
Extreme Southeast CA
No, ethanol is fine to run, just don't let it evap.
davidwyby
1:55 PM
Been buying E free 91 5 gall at a time an hour away and storing it, couple months now maybe. No running issues other than I wonder if it loses some pop or power before it really goes bad and causes run issues. I might buy some fresh 87 with E locally just to see.
Funky sawman
Pony Power
1:55 PM
North idaho
I find that this new gas goes bad quicker in small quantities. Checked the gas at the farm I work at, it's a 100 gallon tank that's filled every 6 months. That gas always smells fresh, even after 6 months.
FergusonTO35
4:55 PM
Boonesborough, KY
Never had a fuel quality related problem in any of my cars and trucks, and I buy the cheapest 87 I can find. I've long been of the opinion that, in a vehicle which is driven regularly and never has the same fuel in it more than a few weeks, corn gas actually keeps the fuel system much cleaner. Alcohol is an excellent solvent, has higher octane, and is much more clean burning than gas. I've read that in some countries ethanol is actually cheaper than gas (or they sell more of their oil to other countries to make $$), so the fuel has a much higher ethanol percentage than here and the vehicles run quite well with it.
FederalQ
3:55 PM
NE Wisconsin
I have had the oppprtunity to speak with a chemical engineer who had helped develop 100 octane low lead aviation gasoline during World War II. I asked him what the benefit of running ethanol mixed with gasoline was and his reply was, ‘the benefit is to the farmers that grow the crops to make it.’
pbillyi69
1:55 PM
USA
exactly that is the only reason we have ethanol from corn in our gas. i have been saying it for years.
pbillyi69
1:55 PM
USA
i like to mix my own so i know for sure that there is the right amount of oil in it and its way cheaper. but i can get clear gas at the pump still.
PissRev
4:55 PM
Ga
I wonder if washing gas like that would remove winterizer?
I'm thinking that the only thing water soluble in gasoline would be the ethanol. Of course I don't know this for a fact.
