Bull Mountains
- 10:14 AM
- Mar 4, 2021
- Bull Mountains.
And FWIW I am making gasoline right now.
Ethanol is about the only oxygenate still in use.So no one brought up oxygen supplements in the package additives.
Winter oxygenated fuel vs summer fuel?
Hell, does anyone even check on that, not likely.
What about deterrents or detergents?
You know... the cleaning additives.
Octane takes a third seat here for me. They sell that in bottles if needed. Old farm tractors run on 75 octane rated fuels but they only sell it new in stale as old-piss from third world countries or that eth *s-word degrading away in your fuel can right now. Put it back out in the sun to help it out some more
Shelf life is about three weeks on a modern summer package pump gas with eth from our local pumps if you keep it in a sealed container out of direct sunlight. Not shut, not covered but sealed up from air transfer to keep the water out and the light ends in. Piss poor fuel is the result if not used within weeks. Forgetabout months, troof.
The best octane is the fresh kind.
Back to your regularly scheduled flame front![]()
Cat cracker gas, olefin feed for the alkylation unit and light cycle oil for the ultra low sulfur diesel unit.I'm huffing some right now,..why what you running right now? I'm interested.
You’ll have to ask someone who used itI was under the impression that racing fuel was like racing oil. No detergents and things like that in it. Inquiring minds want to know?
I ran and raced my 1/5 scale cars for years on camp fuel and 25:1 oil. Super clean and smells cool too.Being that we mix oil in with the fuel octane is subjective? After all you "can" run white camp gas in your saw and its 50 octane and very clean.
My major concern is heat that may be generated from lower octane fuel or carbon deposits through hot spots in the cylinder.
I generally use 90-96 e-free gas with a stabilizer and 40:1 (heavy towards 32:1) .
I was tinkering around with a 1973 318cid and an f-code Paxton blower once and researched" Water injection " I made my own with an old desiel fuel pump and some ss tubing. The point was to make pump gas act like race gas ,aka burn cooler and atomize better .
Obviously adding water to fuel is not helping the octane but it certainly helps with knock and ping when making compression!
I have fuel books all the way back to the 50s and 60s on theory and design and I have spoken with fuel designers in reseach laboratories (coal slurry jet fuel)
A high octane is better burning for lower temperature whether you need it or not but most additives that make the biggest advances aren't available anymore. I ran a push mower on benzene for a summer and boy did that sumabitch cut grass!
Years ago we ran our model airplanes on Coleman camp fuel mixed with drug store casor oil.I ran and raced my 1/5 scale cars for years on camp fuel and 25:1 oil. Super clean and smells cool too.
Used to use the same engines back in the mid-70’s.I haven't flow the models since the 70's. I flew control line combat. All the combat guys used an engine called the Fox 36 BB combat special. I sold off everything but a handful of a Cox .049 engines. Showing my age.
Cox is gone unfortunately.I haven't flow the models since the 70's. I flew control line combat. All the combat guys used an engine called the Fox 36 BB combat special. I sold off everything but a handful of a Cox .049 engines. Showing my age.
