What happens when you straight gas a saw?
Saw Collector
OPE Member
11:10 AM
Here
Good enough?
141260498_412459383347997_8275719843059569347_n-jpg.278604
Must have been running Amsoil lol.
popopboat
5:10 PM
Alright, alright, no free likes for Jeff on your watch :p
Dumpster diving for this one to redempt myself.
IMG_20210226_205323_900x1200.jpg IMG_20210226_205337_900x1200.jpg IMG_20210226_205652_1600x1200.jpg IMG_20210226_205706_1600x1200.jpg
BTW Hole was caused by piston stop while removing clutch, had almost no resistance until it broke through.
5000+
11:10 AM
pa
Trying to go for the thin ring look?
Wonkydonkey
Plastic member
4:10 PM
Sussex, UK.
So was it stuck open, and thus lean / low compression and ran hotter than it should even thou it’s water cooled
kinda looks like its a bit slappy in the boar
11:10 AM
I’ve actually had a decomp stick in on a ported saw and ran a tank through it before I realized it. There’s no scoring. No irregular marks inside. I’m not certain how a leaky decomp could ever cause a 2 stroke to go lean and score
Duce
11:10 AM
Roscommon, MI
You poured oil into fuel tank on an oil injected motor. Ran it in cold weather with stock air filter modified. @Deets066
10:10 AM
Take a piece of white paper and put some drops of the fuel on it. After it evaporates, the oil should be left behind. Try a sample from a can of each that still have a label to compare.
Genius.
Somebody Poast pitchers of all the damage they’ve done using too much oil. The rags you use to wipe off the excessive exhaust spooge will never look the same. Just throw them in the wood stove.
Repped.
