- 2:42 AM
- Sep 4, 2018
- Central Kansas
I thought it was also when I tried it! But it was $11 a gal here!
Same hereI ordered the STP bar lube from Amazon and I will report back after I run it for a while
Running the best bar and chain oil you can find is way cheaper than replacing the bar prematurely IMO.
That depends upon the costs of the bars and the oil. I dunno what it is there, but...
I can go through a couple of gallons of oil a day easily running the 288xp in big oak. At that rate, the bar has to die within a few weeks for me to lose money on using rapeseed vs mineral. Bars on rapeseed usually last me 6 months to a year. By that time, I have saved quit a bit more than the bar is worth, oftentimes I save more than the saws are worth. It costs 7-10€/gallon less using rapeseed vs mineral in Ireland. The cheapest you can find mineral here locally is about €3.50/litre for bar oil - the most expensive can be €13/litre if you go to Woodies(our rather anemic version of Home Depot). So it's about 2.50 a litre more than I get rapeseed at locally at like a corner shop up to €12 or more at best per litre if I got the mineral at Woddies(3.7litres to the US gallon). If I go to the co ops, rapeseed is slightly cheaper, but I like these round figures to work with. So that's more than €9/gallon difference or better. I would have to go through a bar every month to lose money on rapeseed. I have several bars that are a few years old.
I suspect even in the states that if I used the cheapest non tachy motor oil vs the highest tech tachy Stihl product costing twice as much that I would still save quite a bit. It's a chain and bar we're talking here, not the pistons on a super charged 454 chevy. It doesn't need to be overly slathered unless you run dull chain stumping oak in 100* weather all day.
I think how rapeseed makes a difference VS bar oil is the fact it has less tachifiers. Wait, what? Yeah - the fact it flows more means it oils more. It's not a huge difference, but I definitely notice my 288 uses more rapeseed than bar oil. Does it matter? It depends. As far as the environment and costs are concerned, not really. You aren't slathering the local rivers in mineral oil that will take forever to degrade, and it cost a lot less than mineral. But as far as oiling the bar well, it does. I suspect it might burn off or slack off more than tachy mineral, but since you are coating your bar and chain better, it probably doesn't matter from a lubricating standpoint, and it's a good way to shed heat. It also means stingy oilers will oil better as well.
I've used it for years in firewood, mostly hardwoods, with ported saws, without any issues.
Nice!
That thing run pretty good for a stihlIt's not smoking It's freezing out and 80% humid.Typical winter conditions here. AKA - Irish mist.
I think people overthink bar oil. It greases the chain.
