FergusonTO35
- 9:49 AM
- Jul 9, 2017
- Boonesborough, KY
My only point to this statement is that they all are in the same boat as of late is all, Toyota isn’t what it was and neither is Honda Or nissian who are combining. Lots of new Hondas burning oil as bad as Chevy, tundra’s blowing up at 20-30,000 for the last 4 years, fords using and making oil ect. Ram with the new inline 6 gas with compound turbos built into the head. The epa milage and emissions tech that’s required to be used now finally ended up on a Toyota and they aren’t fairing any better that domestic stuff anymore.
I believe every word that you said. Still, I trust Toyota and Honda to overcome these problems better than the domestics. In any event, I don't buy new vehicles. By the time a vehicle gets to me, it has alot of miles on it and I know I'm going to be fixing things on it anyway. One advantage of staying with older vehicles is that there is a knowledge base and aftermarket support for them. Including non-OEM workarounds which can be a lifesaver. Case in point, the Honda Odyssey we used to have had the typical malfunctioning cylinder bank shutdown. The price for me to fix it was several hundred dollars to restore something that never should have been done in the first place. I did some interweb research and found that you could deactivate it by simply unplugging one wire, problem solved permanently!
