Moo's Yo Daddy
- 10:23 AM
- Mar 11, 2017
- Da Barn
YesAre you going to cut squish with that?
What did u think?
Yes
What did u think?
I have a 266 lm trying to figure out how to install an electric starter on,any suggestions?![]()
Just get a 272 jug w/a decomp...I have a 266 lm trying to figure out how to install an electric starter on,any suggestions?![]()
Ya gonna chuck dat in a drill, then twirl it around in thar i take it?I'm all messed up. This is high carbon steel. Don't make like this anymore.
Finally found it.
That's gonna be a runner. Good job man.Had an issue with cutting the inside top area. So I used my drill press and cut a dome on the piston.
Base looks OK. Uniform.
View attachment 60218 View attachment 60219
Looks greatHad an issue with cutting the inside top area. So I used my drill press and cut a dome on the piston.
Thank you.That's gonna be a runner. Good job man.
What type of sealant is "tig'"?I'd probably tig the jug onto the case while your at it. One less spot for an air leak
PermanentWhat type of sealant is "tig'"?
HardeningWhat type of sealant is "tig'"?
Learning so much from this thread i am going to save so much time porting from now on.
Port while you wait could be a big hit he could be successful.You can save even more time by sending your saw over to Moo... I hear he's about to start his own brand of Moo's work saws.
