- 6:37 PM
- Dec 31, 2015
- East Jordan, MI
Moo's AcresPort while you wait could be a big hit he could be successful.
Wow you don't see that every dayHad an issue with cutting the inside top area. So I used my drill press and cut a dome on the piston.
Base looks OK. Uniform.
View attachment 60218 View attachment 60219
Gotta give it to him. He thinks outside the box.Wow you don't see that every day
48mm>50mm ish![]()
I'll take 2 lolView attachment 60245 I believe we need a sticker to put on the saw to get top performance. This is all I could come up with so far...
Did some more reading and some more sanding.
Think I figured out the top inside the cylinder part. Squish band?
This is the second larger cylinder. The one above was the smaller bore one.
Not to shabby my bovine amigo.
Permanent
If it lasts more than 4 hours...Hardening
That it isThis is.... well, it is what it is.
