Wanna learn to Port a Saw
10:16 PM
Nice axe.
10:16 PM
Doesn't it stabilize the piston at BDC?
Would be alot easier if I could cut it off.
If I'm careful, can probably take a saw blade amount off the base in one cut.
One cut with this it's very fast just have a good grip with your boot on top of it wear goggles or look away.20170218_152559.jpg
Whiskers
9:16 PM
Iowa
The best trolls are the ones where it takes a while to tell if they are being jack holes or just real dumb. Funny stuff always pops up in these threads though, take off a saw blade width...lmao
peter92
12:16 PM
maryborough qld aust
is the 395xp a quad transfer , if so could some one explain the diff between the dual and quad please
Peter
Moo's Yo Daddy
10:16 PM
Da Barn
I'm glad you guys got your laughs. I'm cool with that.
I'm not a complete idiot, I can play along with the best of them.
The cylinder extension needs to stay, obviously.
I'm gonna rotate it carefully on a big piece of 2" dowel and use by band Saw. I'll block sand afterwards. Luckily, the tip of a sharpie is almost exactly 1/16". Makes for a handy guide.
Derf
10:16 PM
Long Island NY
Measurements shmeasurements, I just eyeball it so it looks straight, usually after a couple beers too. You don't need those fancy power tools - you can use a hack saw or even a sharp steak knife. I've even had success using large toenail clippers to take little nibbles around the base. Then finish it off with a couple licks from a die grinder to smooth out the edges.
jmssaws
Banneded
9:16 PM
View attachment 60151 View attachment 60152 View attachment 60153
Send it to me and I'll machine it for free
10:16 PM
I wouldn't risk an oem cylinder i would send it to a member or buy a am cheap one ot no need to go extreme a i did a mild woods port and it produced one of the best running 257s I've ever run.
cus_deluxe
terms of service violator
10:16 PM
Michigan
So we got dyno numbers on this bad boy yet or what?
