Walbro WJ carbs and many others .... kits and numbers.
Simondo
9:11 AM
UK
The WJ group thats on the bigger cc saws from Stihl /Husq and others...what carb kits fit...are there kits that fit most ?
So far i have used the ..K15-WJ kit (full inc needle ) .
What can be a pain on these carbs and what seems to be the fixes.
backhoelover
SERVICE MANUAL MASTER
4:11 AM
lincolnton nc
i have a ultra sonic cleaner. i have notice the carb taking a kit and running better with the ultra sonic cleaner. here is the carb manuals for some of the rotary carbs. there are alot more carb now. might can find them on walbro.com. echo makes a tech training video on the rotary carb im going to see if i can get you a copy of it
  • Walbro-WYJ-Series-080805.pdf
  • Walbro-WYA-Series-100908.pdf
  • Walbro-WYK-Series.pdf
  • Walbro-WYL-Series-040109.pdf
  • Walbro-WY-Series-080804.pdf
backhoelover
4:11 AM
lincolnton nc
some of the main problem i see if the rotor ramp wore away. some units have a metal ball that the ramp rides on. also the brass check valve, oring, brass jet can give problems. i have a set of micro drill bits that i use on the brass jet that i turn by had to get the varnish out of it. also some of the wy series carb have a spring on the fuel pump side that help the diaphragm i have seen that spring missing where customer and dealer didnt replace it. cause the carb not to able to pump enough fuel
Simondo
9:11 AM
UK
Same here with the ultra sonic clean ...i do it as the starting point on every carb strip down. Do you have the WJ carb pdf ? could you post it on here to go with the ones you have put up.
backhoelover
4:11 AM
lincolnton nc
no wj :(. i sent luis a email to see if he could send me one
  • walbro service manual.pdf
  • Walbro-Carburetor-Application-Guide.pdf
  • Walbro-Float-Carburetors.pdf
  • Walbro-HDA-Series-OCR-w100.pdf
backhoelover
4:11 AM
lincolnton nc
more
  • Walbro-HDC-Series-120908.pdf
  • Walbro-PZ-Carburetor-Tuning.pdf
  • Walbro-SDC-Series-z082908.pdf
  • Walbro-WA-Series-101208.pdf
  • Walbro-WB-Series-OCR-z031510.pdf
backhoelover
4:11 AM
lincolnton nc
more
  • Walbro-WD-WDA-WR-Manual.pdf
  • Walbro-WS-Series-OCR.pdf
  • Walbro-WT-Series-111108.pdf
  • Walbro-WZ-Series-100908.pdf
backhoelover
4:11 AM
lincolnton nc
here is the tilly stuff
  • Tillotson AJ.pdf
  • tillotson carb to kit reference.pdf
  • Tillotson MD.pdf
  • tillotson_exchange_catalog.pdf
  • Tillotson-HD-090208.pdf
backhoelover
4:11 AM
lincolnton nc
rest of tilly and zama. zama doesnt show flow like walbro and tilly wish they did
  • Tillotson-HL-z083008.pdf
  • Tillotson-HR-z010709.pdf
  • Tillotson-HS-z080808.pdf
  • Tillotson-HU-121408.pdf
  • zamaTechGuide_2007[1].pdf
backhoelover
4:11 AM
lincolnton nc
echo carb info
  • echo Rotary Valve Carb.PDF
  • echo study guide.pdf
Disciple of Monkey's
3:11 AM
From my AM carb kit catalog;
K10-WJ (K10-2J) fits;
Pioneer P39, Cifarelli M88/M88BL, Emak 264 TTA 49/53/59/61/66, Homelite 540/8800/MP55/MP88, Husqvarna P42T/2077/394/61P/700/A55/F55/F65/P42/P52/P62/P650/P7000/P7700, McCulloch MAC 511/611/710/950/960/970/MS55/MS60 Titan51/Titan55/Titan60, Poulan 405/455/525/655/Pro475, Solo 603/670/680/690, Oleomac-Efco 471/171/9811/Efco8, Stihl 051/076
K11-WJ fits;
Stihl 051/064//066, Husqvarna 364/394XP, Oleomac 350/950
K15-WJ fits;
Oleomac-Efco 181/971/981, Stihl 64/66/066
Hope that helps you a little bit there Simon.
Simondo
9:11 AM
UK
K11-WJ fits;
K15-WJ fits;
Sure will Steve....thanks.
Simondo
9:11 AM
UK
Opened up a WJ on a Stihl 066 yr 2001 to put a new metering diaphragm in it. Expected to see a button that hooked onto the fork in the arm (like ALL the kits i found had) . Just a button end on the existing one !...Everything else seemed the exact shape and hole locations ...just no button hook end. Im pretty sure its a long standing kit in this saw and was not in bad shape plus the saw was just getting service with a carb clean . Any one know if the WJ has this or have i just found a cobble ?
3:11 AM
Seen several carbs where the new kit does not have the forked metering lever w/ captured diaphragm and vice versa. My guess is a diaphragm kit was installed. I try to keep the captured diaphragm with the forked lever and the plain lever with the button metering diaphragm, no mix/match. Both seem to work this way OK when done. Personally I prefer the captured version as it lessens the chance of a sticking needle and to my line of thinking a slightly quicker fuel response. Though I've noticed no difference in how well an engine runs with either. Why different ones are made for the same carburetor is anybody's guess, as I surely do not know why that is. All this is from different carburetors over the years, not with the WJ in particular.
Simondo
9:11 AM
UK
There was a forked lever arm in there ..just no hook on the button . Here is the odd thing...put new hooked one and gasket in (lever hight was spot and pop off was solid) no fuel at all through .Dry carb after 20 pulls ! put old button one back in on top of new gasket ..pop in 2 fired and run on 3 . Runs spot on !
Simondo
9:11 AM
UK
That is odd Simon. Wonder if the lever height needs to be different or something.
Really didn't make sense Steve as it checked out as per the correct hight information. This is why i wondered if folks who do the Stihl 066 660 regular (common saw on this site ) would chime in as its my first one ( WJ carb and saw) so dont have any comparisons.
3:11 AM
@tree monkey @Mastermind
