Using JB Weld to secure deflector on 390xp muffler
Colonel 428
1:28 PM
Any reason why JB Weld steel won't work to secure a 20 gauge steel deflector to an OEM 390 xp muffler that I've added an extra exhaust port to? Thanks.
Stevetheboatguy
12:28 PM
Nw IL
If you cannot weld. Rivnuts are your friend. I wouldn't trust epoxy in a situation like that.
Steven
slackinoff
12:28 PM
usa
Even the high temp JB weld won't stand up. It will probably work for a handful of runs and then degrade. I used it to secure an exhaust stud into a cylinder head that had stripped threads. I worked for a couple of tanks before the epoxy broke down.
farminkarman
I like the red & black ones
12:28 PM
Neenah Wisconsin
If you take care of shipping to and from me, I would be happy to weld it up for you.
slackinoff
12:28 PM
usa
Harbor freight has a decent hand rivet gun that will work for not much money.
farminkarman
12:28 PM
Neenah Wisconsin
I like the nut-rivets as well, easy to put spark screen under as well if needed
I recently picked up a rivnut gun for doing muff mods that require a screen. For those that don't need the screen, welding/brazing is the way to go.
farminkarman
12:28 PM
Neenah Wisconsin
Would soldering it hold?
The short answer is no. Technically a lead based solder will stick to mild steel, but the melt temp is pretty low. The muffler temp could easily exceed the melt temp of the solder. As Steve said, brazing absolutely would work.
MG2186
12:28 PM
Summer,IA
I’ve been silver soldering my pipes in for years and have never had any troubles
