Ultrasonic cleaners? What can I clean
legdelimber
12:36 PM
N.C.
I need an ultrasonic bathtub!
Philbert
Can't seem to find a link anymore, it's been a long time.
But many years ago there was a relevant article about workers in an electronics plant.
The workers were loading and unloading parts in the tank of an Ultrasonic cleaner.
Workers weren't following protocol and were putting their fingers into an operating cleaner tank and it eventually took its toll.
Fingertips got kinda rubbery as the bones were slowly eroded by the cleaner energy.
I think the liability lawyers were trying to blame (ghetto lottery) the solvent maker too.
Story didn't make it clear if the behavior was employer/job retention motivated or just complacent workers.
huskyhank
11:36 AM
I use whatever solution seems to be a good solvent for the material I want to remove. Mostly I keep plain water in the Ultrasonic tank and add a plastic cup of the cleaner and parts floating in the tank. Its easy to change solvents and to fish out your parts. Also uses only enough solvent to do the job rather than the whole tank full.
It is very important to rinse well. A vibrating rinse in a cup of hot water in the machine, then plenty of hot running water. If you are concerned about any acid damage, a rinse in baking soda water will kill it.
huskyhank
11:36 AM
If your floating cup tries to tip over you can make a little holder by laying a small strip of wood across the tank and clipping the cup to it to keep it upright and from moving around.
Also, don’t put parts loose in the tank. Hard parts vibrating against the walls might wear a hole.
Partner
5:36 PM
Poland
Nie bylo sitka w gazniku i zapchany jest kanal śrubki H myjka ultradźwiękowa pomoże? przepcha to ? Nie ma reakcji na srubke H / pilarka odpala i parkocze a ciąć się nie daje / dot pl
huskyhank
11:36 AM
Don't most come with some type of basket?
Philbert
I guess so but it seemed worth mentioning.
Also, for best results you need to run the tank full of solution to get the micro air bubbles out the first time you use the solution. Until then its not cleaning 100%.
Wonkydonkey
Plastic member
4:36 PM
Sussex, UK.
Umm,, intrigued that you can read English and reply in polish..
Bilge Rat
12:36 PM
savannah georgia
Philbert
Jewelers use insulated solid copper wire laid across the top of the tank to suspend rings and such in the tank for cleaning.
The screen tea balls will hold small parts and suspended into the solution. They come in 2 sizes on Ebay.
ucm931
12:36 PM
Michigan
I put a glass jar with the cleaner and muh parts in the water.
legdelimber
12:36 PM
N.C.
I'm fond of using the bottom half of those flimsy plastic water bottles for parts holders.
Generally, if I have the fluid level in the bottle half a little bit higher than the fluid level in the cleaner tank, the bottle bottom will sit in the basket and not try to tip over.
Philbert
Chainsaw Enthusiast
11:36 AM
East Dakota
"There was no strainer in the gaznik and the channel of the screw is clogged H ultrasonic cleaner will help? pushes it? There is no reaction to the H bolt / the saw starts and splits and cuts do not give / dot pl"
Philbert (and Google Translate)
exSW
'Cause Thomas is a poopyhead
12:36 PM
United States
I clean my carry pistol in mine. Dump it in whole(unloaded). Field strip after it's done,blow it off with canned air ,lightly oil the slide and reassemble. Good to go. I use Dawn for everything.
trooney
Admitted Woodaholic
12:36 PM
The land of pleasant living
dustinwilt68
Wilt Built Work Saws
12:36 PM
Southwest PA
I have used it exclusively for years now, never a problem till this batch of 5 gallons, I am currently trying a new solution out, will report my findings in the thread I revised from the past
dustinwilt68
12:36 PM
Southwest PA
I used purple power last night from DG about 2 cups of it/ 2 gallon of water, did ok for a hour, then started turning the cylinder darker.
stihl_head1982
Here long time
12:36 PM
USA
I've been wondering about the cleaners in the ultrasonic.
These posts are helping some
