Ultimate "Firewood" Saw
hseII
Heef
2:41 PM
West Georgia
In an effort to keep this post from being three pages long, here is the bare bones. I have two saws, neither do quite what I want, and I am considering buying a 3rd saw.
I have two totally stock Stihls, an MS290 with a 20" bar, and an MS661-CM with a 36" bar. I use these saws solely for firewood to heat my house, which can include felling smallish trees (18-24") and bucking as big as 50".
The 290 is dead reliable but underpowered. The 661 is not so reliable (won't hot start sometimes) and underpowered for the size bar I am running. I am open to basically ANY solution to get a saw(s) that perform "well" in all hardwoods up to 50" diameter.
One consideration I had was putting a smaller bar on the 661 and using it for my primary bucking saw, and getting a larger, or highly modified saw to run the 36" bar. Is that nuts?
Then I saw there is a "new" 462 that weighs exactly the same as my 290...but has nearly double the power. That sounds too good to be true.
Things that are important to me, in order, are:
Reliability!
Torque
Antivibe stuff...I have nerve problems.
I don't have any preconceived notions about much of anything, I am too green. I have no brand loyalty, but do have access to a Stihl dealer that gives very decent pricing. I have been doing the firewood thing since 2011, but thats all the experience I have. Please feel free to enlighten me if I do not seem to grasp something, I am not very well versed in this stuff. I am also happy to share more information, I just wanted to keep this short for you guys.
Thanks in advance,
FTM
MS461R
Lightning Performance
2:41 PM
East of Philly
1:41 PM
I thought you had everyone else cut your firewood for this winter already.
I give all those cookies away to my neighbors they want em. I don't like messing with them. They don't burn all that well, and they're messy.
I did buck up the stuff that was leftover though.
FordTruckMan
2:41 PM
Ohio
So in a crazy turn of events, I managed to snag more than a full log truck load of premium timbers that were headed to a scragg mill, all 20-ish" diameter or less. Rough estimate is a solid 8-9 cords. I normally scavenge all of my firewood, but in doing so, at a property being logged down the gravel road a piece, I got to talking with the owner and he hooked me up good.
So now, I won't be needing my 36" bar too much for a few years. I'm still getting it ported though, so it makes me wonder if I should just get a shorter bar for it and do some pushups lol. The 661 weighs 16.3 lbs and the 462 weighs 13.0 lbs, power head only obviously. 3.3 lbs is a big difference to cut with all day, but it's all going to be easy cutting on straight-ish timbers.
So the question I suppose, is what size bar would balance the best on the 661? It's really nose heavy with the 36" bar, but I feel like a 20" bar would just look plain silly on a 661?? Has anybody run shorter bars that can comment on the balance? Would a 25" bar be just right?
2:41 PM
East of Philly
Look silly....weight helps bucking.
My 066 is wearing a 24" now for bucking 32" red oak logs. It cooks! 8 pin wanting a 9
jk14
2:41 PM
Glenside Pa.
25" ES or 28" ES Light, feels right to me on a 661 for bucking firewood
Backtroller
1:41 PM
Land of Badgers
I have both a 24” es light in .404 and a 32” es light in .404 for my 661. I’ve been wondering why I even have my 462.
I’ve barely used the 462 since I got it. It’s a great saw, light and powerful but I really like the 661 after Kevin built it. I reach for that more often than not.
FordTruckMan
2:41 PM
Ohio
So then what your saying is you would like to just send your 462 to me since you aren't using it anymore? LOL!
I have never run a .404, I will have to research this a bit.
Thanks for the responses guys, looks like maybe I can get away with not buying a new saw?? Worst case I end up with a spare bar for the 661.
2:41 PM
East of Philly
Dude....its all about what you want. You need more trigger time on more saws :sisi3:
Edit: 404:coleman:
FordTruckMan
2:41 PM
Ohio
Edit: 404:coleman:
lol, I did admit I was green at the beginning of this thread. I agree I need more time with the saws, and hopefully now that I am a member of this forum I will continue to learn at a slightly faster rate than the last 8 years lol.
pwheel
Finis Origine Pendet
2:41 PM
MA
That sounds right. For comparison, a 25" ES bar is slightly nose-heavy on my ms460.
To the OP: There's over 120 dead oaks on our neighboring 75 acres and I'll be doing my share of the cutting, all of which will end up in the neighbor's firewood processor. If I had your rig, I'd run a 28" ES Light on the 661 (stock) for felling & bucking and sell the 36" bar and the ms290. Resize the full comp chain for the 28" bar w/ 7-pin sprocket; not sure anyone wants to sharpen that many cutters on a 36" bar. For limbing & smaller wood, I've found an ms261 to be efficient and quick to sharpen. That's just me; lots of folks prefer the power of a ported 661.
