- 2:41 AM
- Dec 3, 2015
- Banner Springs Tennessee
I think you're pretty handsome too.![]()
I was gonna be a model......
My 361's are just as smooth as the 362 with a little "trick" most don't like but I do. Bad parts and I'm all rebuilt![]()
Pull the spider mount under the bar. It will feel sloppy so go sharpen your chain. Smooth as silk for a hybrid AV system. It will not handle anything over a 20" es with the spider removed. You can cut a soft one down then run the 24" I don't.What is your 361 trick? @Lightning Performance
You're already a hand and leg model.
I'll do anything after 6 cans.
My ultimate firewood saw is the one nephews are using to get firewood in.
Sent from my SM-G965U using Tapatalk
Yes, I have a ported jonsered 2159 and 2165OK I double checked this morning, I did indeed have the pin pushed in and the oiler a full 1/4 turn.
When you say hot rod 60cc saw, do you mean getting one of those models ported as well? Do guys port the smaller saws too?
I'd suggest putting a lite bar on it as wellOk my buddy got back to me with pricing on a new MS462-CM. With a 20" bar it's $1123.81, with 25" bar it's $1133.85. these are out the door prices. How does that sound compared to what you guys have seen? Tax is 6.75% where I'm at. I think it's a decent price. I'm thinking I will go with a standard 20" bar, and if I decide down the road I want something a little longer on it, I'll look at an aftermarket light bar. Maybe a Tsumura?
462 I ran was sahweet!It's sadly the way of "progress", regardless of actual improvement. Form what I read, the 462 in a darn fine saw, and I would like to try one. But, I don't think it will quite as capably replace the 046/460/461 when you're in hard wood and running a 28" bar. I'd be happy to be wrong though!!
