scottw99
New OPE Member
Hello, first post here. Info to get started:
Stihl 066 red light converted to unlimited coil with proper flywheel.
I purchased the saw with a damaged piston, cylinder was in okay shape. Seller gave a piston kit with it, I installed said piston kit. Installed new seals and pressure/vac tested it, installed new fuel line, fuel filter, impulse line, intake boot, carb kit, spark plug. Fresh 91oct with 32:1 Bel-ray H1R.
It's starting and idling just fine, but I can't get it to four stroke at WOT - worried about it running lean. The new AM impulse line doesn't seem to be sealing super tight against the bottom carb nipple so I pulled a bit more through the hole and the issue is still there.
Seems like it's running lean, or not getting enough fuel delivered, any ideas? I turn the H needle out fully and it dies before it will four stroke at WOT.
