Redfin
Meh...
- 3:15 PM
- Dec 24, 2015
- Central Pa
If a circlip goes flying and you swear you heard it hit the bench, check inside the crankcase before you start it.
In addition to that : you may as well empty the bar oil as well ,because you really don't want to have to change a second time in less than 10 minutes .#4638
Zeus himself can't stop fuel from pissing out of the fuel line once the carb is removed...empty the gas tank before you tear down.
Just crack the cap.#4638
I usually clamp a pair of forceps on the line before I take it off the carb. Very handy tools.
I have tiny plastic forceps that can clamp the fuel line while it is still on the carb.
They remind me of my dad, I had to use them when I was flushing his mainline in his chest for him.
Connect throttle rod before refitting airbox...
Fit 660 intake boot with cylinder, not afterward like a spastic with long nose pliers and swearing
Sent from my SM-G900I using Tapatalk
