tree monkey 661 turning 15k?!?!?
Keith Gandy
Maxima K2 40:1 87 Pump Gas
1:30 PM
Provencal, Louisiana
A plug doesn't get a signal. It discharges the energy created when the field collapses.
But like Mike said the plug can still get interference even through waves. Theres a reason they used certain plugs back in the day around electrical/electronic equipment
jmssaws
Banneded
1:30 PM
If a WJ69 will run a 064/066 out to 15000 why wont it on a 661?
Because it has a limited coil.
How could all these different people put a wj69 on one and not get a unlimited saw?
I have no doubt it's turning what the tach reads but it's not from just a wj69 like we are told,also if the coil is not limited what difference would a spark plug make?
Put a wj69 on one and screw the high shut and it will still 4 stroke or burble wfo no load,how can that be?
I'm not doubting that it's turning what it is but it's not just from a standard carb.
Everyone has gotten 14k from a carb but over time it will slow back down,go wow does that happen? The only thing left is the coil so how can it slow it down if you have control over the fuel and air?
Keith Gandy
1:30 PM
I think Scott ask about the plug for a reason but not sure?
