Tools for saw work
Genius
First member of ASlite to receive a infraction
1:40 AM
Uncle Willys basement
Tell me that you buy this stihl pressure pump for only 100 $ new in a box , and i will jump from a skyscraper
Don't jump. Technically it was listed as used.
I believe that by used the seller meant that he opened the box.
I was shocked that there was only one other bid. I was expecting to loose the auction at the last second.
panteliss
7:40 AM
Europe
this set go over 350 euros on dealers here
angelo c
Coal Member
1:40 AM
When i do this , i must go to doctors to see me if the alszhaimer have knock my door
his father bought it on one of his trips to the "motherland". he has a friend who owns a dealership. told him he never ever used the tool before. (said not needed.)
uses screw drivers...haha
angelo c
Coal Member
1:40 AM
Aggression progression.....
1:40 AM
angelo c
Coal Member
1:40 AM
Majorpayne
12:40 AM
Southern Illinois
panteliss
7:40 AM
Europe
i was just about to order one i been adding to my collection a little at a time was going to get this and the intake side http://www.ebay.com/itm/321731328286?_trksid=p2060353.m1438.l2649&ssPageName=STRK:MEBIDX:IT
for theese series of stihl machines
1119, 1121, 1123, 1125, 1127, 1129, 1130, 1132, 1135, 1137, 1144,
1145, 4116, 4126, 4135, 4113, 4128, 4133, 4134, 4134, 4128, 4137,
4138, 4139, 4140, 4144, 4146, 4147, 4149, 4203, 4205, 4223, 4226,
4227, 4229, 4232, 4237, 4241, 4244, 4246, 4252, 4259, 4311, 4600,
4601, 4137, 4601
panteliss
7:40 AM
Europe
Is this pretty handy? Used too push the bearing off of crank shaft?
This tool can be splitting the case from the flywheel side for about all chainsaws and some other machines that the stihl product, also can close the case of theese machines
For the bearings that you asked this tool push the shaft but sometimes the bearings come out with the shaft sometimes stay in the case.
the best method to pull out and push in bearings is heat the case with a hot air gun over of 150 celsius then the bearings fall down themselfs , never tap the bearing to put them into the case .
when you tap a cold bearing to push it into the case the bearing shaving the magnesium . its some tenths of milimeter biger but theese tenths are enough to make the bad thing
