Tools for saw work
8:30 PM
I used Randy's method for installing bearings on a 046 and the heat gun really worked great just a cheap one but works great none the less.View attachment 14868
lmao which randy and i have been looking into one of the heat guns also but i was thinking porter cable or dewalt brand . i wasnt sure how well they worked in heating the cases
rattler
8:30 PM
NC
Mastermind. It was so much quicker with the heat gun. I am sure the brand name,s would be better when this one lays down that,s proubly buy.
Sent from my XT1060 using Tapatalk
8:30 PM
well the porter cable is a 1500 watt for 34 dollars and the dewalt is i think 1750 and its almost 60 all depends on wallet and want
panteliss
2:30 AM
Europe
You made that?
I think we have a winner right there for the best home made tool so far.
Yes i made , is a copy from the stihl tool in more simple version..................... and dont cost 300 euros ;)
if you like to make one i can sent you templates with instructions FREE
panteliss
2:30 AM
Europe
Explain to me how and I will do it!
The multi holes tools can not explain here because you must find the center of about 50 holes with the center of the shaft for diference stihl models also it have spindle with left hand threads and right hand threads
if you like i can sent you templates FREE
The clutch side spliter is more easy you must find the center of the bar studs with the center of the shaft not so easy if you like to be for all models
again templates and for this FREE
panteliss
2:30 AM
Europe
beautiful work!!!!!
The last one can probleby work on Huskies as well
The clutch side can work in some huskies depent of the distance of the two bar studs , you can modify the tool , or you can made one for the huskys tomorow i will put some pictures how is for huskys
Burky
7:30 PM
Panteliss, I would love these templates!
stihl_head1982
Here long time
8:30 PM
USA
I'm interested. You installed and removed the crank without heat. Very good!
Backtroller
7:30 PM
Land of Badgers
Anyone recommend a good set of colbalt drill bits? I had bought a set of Craftsman and they seemed ok, but they all pretty much all worn out now. Is there a good set at a reasonable price out there?
Majorpayne
7:30 PM
Southern Illinois
