Todays snag
Car wash guy
10:30 PM
Bristol va
Picked up this minty 288 in NC. Got a chance to run it yesterday I see what the hype is all about. Makes my picker stick out just a little
Sent from my Lenovo TB-X103F using Tapatalk
10:30 PM
HELP, having trouble with a Stihl 046. Guy said the recoil broke so he did not run it for about 6 months. Said compression is good (and it feels it). I figure bad gas and needs fuel filter. Then he tells me he shot either in it and can't get it to pop. Figure must be the spark.
The air filter looks OK, so I pull the plug. It is shot, gap way too wide and the screw thing on the end is stripped. So I replace the plug and pour a little fuel into the carb and still no pop. So I replace the coil … same. I pull the flywheel, it did not strip the key, and the magnet seems strong. Still no pop.
I'm thinking maybe the switch is shorting out??? Anyone else have any ideas? This one is stumping me. Any advice appreciated.
psuiewalsh
Basement Bodging
10:30 PM
Nottingham,pa
Did you remove the kill wire from the coil and test?
beaglebriar
The Peanut Gallery
10:30 PM
Warren Center, PA
How's the intake boot?
10:30 PM
No, but good idea, thanks. Will do that before I replace the switch.
I think if I have compression and spark, I should get a pop no matter what after pouring a bit of fuel directly in.
beaglebriar
The Peanut Gallery
10:30 PM
Warren Center, PA
Did you put it in the sparkplug hole or the intake? I get better results pouring it right in the plug hole. Pistol grip oil can with mix in it works great.
Here for the Yum Yum Sauce
9:30 PM
I did not pull the muffler because the compression feels good.
Have seen numerous saw's that "felt" like they had compression and did not. It's just easier to pop the muffler and find out what is going on.
Here's a collapsed ring that still felt good. Saw had all kinds of brand new parts put on it before it came to me and still would not run.
