Todays snag
4:47 AM
What a waste of nice clean paper...
Don't be getting all jelly.
Olympic down front and one of the "good" later Poulans to the left?
Yes it's an Olympyk mayhaps a 252 ? The sticker is pretty warn away. He had it listed as a Husqvarna lol. And a Poulan 3450
exSW
'Cause Thomas is a poopyhead
5:47 AM
United States
If the Super 250's a non runner I could use a clutch cover.
countryhog
BTDT
4:47 AM
NW Arkansas
That crossed mind too. The guy used to cut wood then got a wood pellet stove so hopefully they only need rubber stuff.
If it does you could have a goodun. If it needs seals that is a different matter. After many years I still haven’t found a AM set that will fit. Last set I got had to come from Italy, not cheap. Went and installed one of the sets, then discovered the case gasket leaked. Not split the case cause then I need a case gasket. Looking for some right now. Keep us updated
4:47 AM
So the factory seals aren't a standard size?
Where did you find a part number?
JTV10
4:47 AM
Wisconsin USA
What parts are you needing?
I found all the parts online at at my local dealer. Did a complete tear down and rebuild, the only part that was a pita to get was the bearing with the integrated seal. Still waiting on the clutch cover and carb box cover other than that its all back together.
redlight066
5:47 AM
Taylors SC
I was at the parts counter and Bought this off a landscaper yesterday around 11:00. He got the bad news from the service dept. Bearings were shot. I offered him $100. He said yes waaaayy too fast. Prolly could have got it for less.
Got home and swapped the crankshaft from a donor, and new seals. Carb replaced as well. Had it listed on CL by 2:30. Sold it at 6:00 for $350:D
ABC9DEB1-F80C-4657-A88B-1CD6BDF29A58.jpeg 0C5B42D5-1820-46B5-B89D-D0332393021F.jpeg
