Today, on this episode of 394xp....
5000+
5:18 PM
pa
What if you hit those buffed plastics with a good clear spray paint?
redlight066
5:18 PM
Taylors SC
Wow....that's a Lotta work man
Experimenting with some different methods and seeing what worked took some time. Wet sanding seems to be the best way and the results are only going to be so good (on heavily oxidized plastic) It just wasn’t in the budget to buy all new plastics. Going forward I think I could do the cylinder cover in about an hour or so.
jacob j.
Only the weird
2:18 PM
Coastal Oregon
Project on hold. Urrrggg. FYI the 395 crankcase assy. does not come with the oil tank vent. It is NOT the same as the 394. Oh well. I was looking forward to putting this together today.
Ahhh, they should be the same.
I think they did update the oil tank vent on the newer 395 crankcases and made it the same as the vent on the 390XP crankcase. I remember
seeing that change at the dealership last time I was looking at new saws.
redlight066
5:18 PM
Taylors SC
3mm spring roll pin vs 5.5mm opening in the new case. I was lacking a few smalls so I put an order together.
I probably could’ve riggsomething up but given the amount of effort I’m putting into this. I’m not doing anything half assed
qurotro
Cookie Cutter
4:18 PM
Ar
It won’t matter what I use. It’s still going to leak. :)
So true... Its just a plastic tube with a nipple on it.. I'm surprised the first time I wash my oil tank with gas. There's a little gas fountain..
beaglebriar
The Peanut Gallery
5:18 PM
Warren Center, PA
I found this stuff really makes plastic shine. Kind of a happy accident, I was cleaning oxidation off some cases after running them through the USC and got some on the tank. Give it a whirl.
srcarr52
5:18 PM
Iowa City
They just had to go and fix something that wasn't broke.
5:18 PM
The newer 395 I have here has the same plastic oiler tube piece in the tank as the 394 I have here. I know for sure because I had to fix the one on the saw because it was installed incorrectly. It’s supposed to go up in the corner of the case right above the oil fill cap. If you don’t do that... it will leak oil guaranteed when sitting. No idea about the vent that goes in the cases being the same or not, didn’t compare them.
