- 3:22 AM
- Nov 24, 2023
- Northern Idaho, Ehh
I need to make a throttle rod for a Stihl 075, what is recommend material (or what has worked for you) to bend out a new throttle rod?
I bought a 1111 182 1501 but found out that it is about 1.5 inches too short, instead I need the 1111 182 1500 which mates up to a 1111 180 1501 trigger (that is the assembly number - breaks down into the trigger 1111 182 1001 with an eyelet).
It appears the 1111 182 1500 is the older and harder to find part, so I figured that I would try my hand at bending my own throttle rods. I am sure that this won't be the last hard to find throttle or choke rod I will need.
I have access to MAP gas and Oxy/Acetylene to heat material to bend, just not sure what are good options to use.
