- 5:42 PM
- Dec 3, 2015
- Banner Springs Tennessee
I figured you for a John boat kinda guy.
I'm actually a vee hull sorta dude.
Hello Gents. I have found myself in need of a 394XP flywheel. I've got worthless government notes.......or can trade in parts.
I got one randy with crank u want it ?
Heat.
Looking for a "heat shield" that goes between muffler and cylinder for a 254xp.
Have you tightened it up and smacked the end of the bolt with a hammer?
Agreed with the above, sometimes desperate times call for desperate measures. I have been known to pull the case bolts out and use the splitter to force the case half and flywheel off.
Joe
Load up some tension on the jack bolt. Pick the whole saw up slightly off your bench(1/2") while holding onto the puller. Then grab a bfh and give the end of the jack bolt a good smack.
Just a thought.
Heat.
