Johnmn
- 4:22 AM
- Feb 18, 2016
- Minnesota
Or just buy a small spline picco rim from @Definitive DaveTo convert you will need a 5105 clutch drum, a Stihl picco 7 pin rim. You will need to bore the rim I.d. out to .752” then with a 1/8” carbide Dremel bit you will need to extend each rim key way until the rim fits the shaft. To be able to use the same chains you will need to shorten the tail on your bar and drill 2 new adjustment holes in the bar approximately 1” closer towards the nose. Sounds like a lot of work but it’s really not that time consuming. I mentioned using the carbide bit in the Dremel because those rims are HARD. I tried a jewelers file and took the teeth off.
