- 10:51 AM
- Jan 28, 2016
- Dike, Iowa
Thanks Poge, I will study it in greater detail with the documentation in hand.
Mark
Mark
I have the Bosch coil/flywheel combo, my issue is the original timing mark is at the 10 o'clock mark and the one on the coil is at the 1-2 o'clock mark. I'll have to dig up a set of calipers to set the saw to .11 BTDC as shown and transfer the timing mark, and I also learned I'll need a new plug wire as my old one is shot (and may be the cause of the "death" of my previous coil).Either way, I'm pretty sure you'll still need the Bosch flywheel/fanwheel along with said ignition module to get the timing right. And if you're this far into it I'd recommend the "Foggy Fix" for an electronic module just because.
I could very well be looking at the wrong mark, but when I utilize the original holes in the base the mark I was looking at is in the 1-2 o'clock region.I somehow deleted half the text in that post. Oh, well. Not important anyway. LOL
That 1-2 o'clock mark just sounds wrong. If the coil is mounted to the plate correctly the mark should be in that 10 0'clock area. I do have a SEM 056 (bad ignition). I'll dig it out if no one else jumps in with something more defintive on the subject.
(Kill wire rub-through is also a notorious problem with the 1115 saws.)
To add to the above it might have been 10-12 years that avatar picture was taken .That was a 117 feet red oak damaged by 90-100 MPH straight line winds of a tornado .It was put on the ground with a 2100S Homelite using a 48" McCulloch hard nose bar . Between 3 saws ,Mac 125 ,Stihl 084 and Homelite 2100S I'm not sure if there is much difference other than speed .They've all got enough power to pull long bars and they are all heavy . I'll just say the difference between 36" and 42"-48 "bars is like night and day.
If it doesn't go on it's own is where the old dozer comes into play
